- #421
atyy
- 3,381
cfrogue said:I am putting a clock on the right end of the rod of O'.
From this there ensues the following peculiar consequence. If at the points A and B of K there are stationary clocks which, viewed in the stationary system, are synchronous; and if the clock at A is moved with the velocity v along the line AB to B, then on its arrival at B the two clocks no longer synchronize, but the clock moved from A to B lags behind the other which has remained at B
http://www.fourmilab.ch/etexts/einstein/specrel/www/
I am beginning to think I cannot sync to zero when the origins of O and O' meet.
Oh, I could, but how can all the clocks on the rod of O' sync up?
It seems all clocks on the rod of O' must be synched in advance.
Thus, there must be a time in O and a time in O' that may or may not be equal when the centers of O and O' are coincident.
Do you agree?
yanni - the rain must fall
There are two meanings of synch.
In relativity, the common one is synch all clocks that are stationary with respect to an inertial observer. So for example, if O' places 3 clocks, one at the left end of the primed rod, one at his location at the centre of the primed rod, and one at the right end of the primed rod, he can synch all 3 clocks - these 3 clocks will not be synched for O. Similarly O can place clocks at the left, centre and right of the unprimed rod, and synched them. these clocks will not be synched for O'.
There is a different operation, which I think you call synching, but is not called synching in relativity. When the worldlines of O and O' intersect, that is an event, and O can do a global shift of his unprimed time and unprimed space coordinates so that the event occurs at (x=0, t=0) for him, and O' can also do a global shift of his primed time and primed space coordinates so that the event occurs at (x'=0, t'=0) for him.
Love the guitar solo!
