Deriving Inverse Trig Functions
quozzy
Alright, I'm not technically stuck on this one, but I consistently get a result that disagrees with what Wolfram Alpha shows when I enter the problem to check my answer. Sorry 'bout the lack of LaTeX, but it should be simple enough to read. Here goes:
Problem:
Differentiate y=sin-1[x/(1+x)]
Basically, I rearrange for
sin(y)=x/(x+1)
then use implicit differentiation to yield:
* ---> cos(y)*(dy/(dx))=1/(x+1)2
Substituting with:
cos(y)=sqrt[1-sin2(y)]
I get:
cos(y)=sqrt[1-x2/(x+1)2]
which simplifies to:
cos(y)=sqrt(2x+1)/(x+1)
Dividing both sides of the original equation (above, marked with a star) by cos(y):
dy/(dx)=1/[(x+1)sqrt(2x+1)]
Which, if you don't like surds in the denominator, can be simplified to:
sqrt(2x+1)/[(x+1)(2x+1)]
I've done this question several times, and re-checked all my working. For the life of me, I can't see where I go wrong, yet my result is slightly different to what it should be. Any suggestions would be most welcome.
This is pretty close (and equivalent) to the first alternate form of the derivative on Wolframalpha.
What do you think it should be?
Huh. It appears you're right. I had even tried entering <my answer> - <w.a. answer>, and it came out nonzero, but I must have mistyped something. Well, I'm glad I'm not missing anything. Thanks for the clarification!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
