Deriving speed equations | Elastic collision
The discussion centers on deriving speed equations for elastic collisions, emphasizing the conservation of momentum with the equations provided. The user is attempting to express final speeds in terms of initial speed and masses but is struggling to find a necessary relationship. They express uncertainty about using energy considerations in this context. Clarification is sought on how to relate the variables effectively to solve for final speeds. The conversation highlights the importance of understanding both momentum and energy conservation in elastic collisions.
I_Try_Math
Derive the equations giving the final speeds for two objects that collide elastically, with the mass of the objects being ##m_1## and ##m_2## and the initial speeds being ##v_{1,i}## and ##v_{2,i}=0## (i.e., second object is initially stationary).
##p_i = p_f##
So far I've got:
##p_{1,i} + p_{2,i} = p_{1,f} + p_{2,f}##
##p_{1,i} + 0 = p_{1,f} + p_{2,f}##
##m_1v_{1,i} = m_1v_{1,f} + m_2v_{2,f}##
According to the textbook, the final speeds should be written in terms of ##v_{1,i}, m_1, and m_2##. It looks like I need another way to relate everything with an equation to solve for the final speeds but I'm drawing a blank. It doesn't seem like I can use energy considerations? Any hints are appreciated.
Why not?
" two objects that collide elastically"
Likes I_Try_Math, pines-demon and Chestermiller
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
