I Deriving the conformal Laplacian
  • I
  • Thread starter Thread starter Ssnow
The discussion revolves around deriving the conformal Laplacian, specifically the equation involving the metric g and its relation to the Laplacian and scalar curvature. The context includes the use of a normal frame where all Christoffel symbols are zero at point y. The goal is to express the Laplacian in a conformal manner, referencing Sniatycki's book on geometric quantization. The original poster, Ssnow, later indicates that they have resolved the problem. The exchange highlights the complexities of working with the conformal Laplacian in differential geometry.
Ssnow
Hi to all!! I have a problem to derive the conformal laplacian
\sum_{m,n}g^{mn}(y)\partial_{q^m}\partial_{q^n}(\psi|\det{(g)}|^{1/4})(y)=\sum_{m,n}|det{g}|^{1/4}(\Delta \Psi -\frac{1}{6}R(y)\psi(y))
where $$g$$ is the metric associated to a Levi Civita connection in a normal frame, we have that in the point $y$ all Christoffel symbols are $$0$$ and $$\Gamma_{ij}^m,k(y)+\Gamma_{ki}^m,j(y)+\Gamma_{jk}^m,i(y)=0.$$
In practice the aim is to find the conformal expression of the Laplacian (Yamabe operator) ... the source is the book "Geometric quantization and quantum mechanics" Sniatycki J.
Thanks,
Ssnow
I solved the problem, Ssnow
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
