Describing a Solid Ice Cream Cone with Spherical Coordinates
WhiteWalker
Q: Consider the solid that lies above the cone z=√(3x^2+3y^2) and below the sphere X^2+y^2+Z^2=36. It looks somewhat like an ice cream cone. Use spherical coordinates to write inequalities that describe this solid.
What I tried to do:
I started by graphing this on a 3D graph at http://web.monroecc.edu/manila/webfiles/calcNSF/JavaCode/CalcPlot3D.htm now since this is a solid I thought that all I need to do was find the coordinates where the graphs intersect. Am I on the right track?
What I tried to do:
Yes, but that's not much of a start. Pretty obviously the surfaces will intersect in a circle in some horizontal plane.
BTW, when you post a problem, don't delete the three parts of the homework template. They are required, and are there for a reason.
Thanks for correcting me. :)
The reason why I have this posted is because people I was working with had different ideas of what we where solving or how to solve it.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
