Design Steel Pole: 3 Segment, 50ft, Max Wind 110mph
The discussion centers on designing a 50-foot steel pole composed of three segments with specific height and diameter requirements, intended to support various equipment while withstanding wind speeds of up to 110 mph. The proposed diameters and gauges for the segments include 6 inches for the base, 5 inches for the middle, and 4 inches for the top, although the adequacy of these dimensions for load-bearing is questioned. Participants emphasize the importance of strong connections between segments and the pole's foundation, as well as the impact of wind load based on equipment size and positioning. A bending moment diagram has been created, but further guidance is needed to determine the appropriate pole dimensions based on the calculated loads. The conversation highlights the complexities involved in structural design and the need for precise calculations to ensure safety and stability.
AnnieFatima
I need to design a steel pole in 3 segments.The base segment needs to be
25 ft high , the second segment needs to be 15 ft and the third one 10ft high.So that when mounted on top of one another their total height will be 50 ft.Their diameters need to be within 1.6-7 inches.
The load on the pole will be a 40 kg cabinet at 5 ft , a 1kg equipment at 10ft ,a 5.4 kg equipment at 35 ft, a 3.6 kg equipment at 40 ft and a 2kg light at the top height of 50 ft.The area where the pole will be mounted has a maximum wind speed of 110mph and there will be no snow.I need to calculate the loading on the pole and then calculate the required diameters of the segments and the steel gauge/metal thickness.
Can anyone please help me with this.
Going through the internet a solution that I came up with is to have a diameter of 6 inches and gauge 7(0.18 " /4.76 mm) sheet for the base 25 ft section.
A 5 inches diameter and gauge 9 (0.15"/3.96mm) sheet for the second segment.
A 4 inches diameter and gauge 9 (0.15"/3.96mm) sheet for the third segment.
But I can not justify if this will bear the load and all.
Also The segments will be joined to each other through plates and the pole will be joined to the ground through a base plate,anchor bolts and a foundation.
Free standing it is, no guy wires can be used.
(1) When dealing with wind speed loads the sizes of the equipment boxes will matter - do they present a large or small area to the wind .
(2) Also by how much are they offset relative to mast - are they close to mast or on brackets with significant leverage action .
(3) There are tables available for estimating wind loads .
When you have your loads sorted out you will need to prepare a bending moment diagram . From that and dimensions of tubes you will be able to calculate stresses and deflections .
Sorry, but what do you mean by a mast.As for the equipment the largest one is the 600mm X 760 mm which is the cabinet.The rest of the equipment are lights and buzzers which have a small area.
I have made a rough bending moment diagram and have the moment at the ground-line. I don't know how to proceed further and find pole dimensions.
A long vertical pole is often called a mast because of the similarity to a ships mast . It's just common usage . I'll use the pole word from now on .
Can you show us your bending moment diagram ?
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
