Design & Theory of Steam Platens for Rubber Curing Presses
  • Thread starter Thread starter sriram123
    Design Steam
The discussion focuses on the design of steam platens for rubber curing presses, specifically the steam flow path dimensions and patterns. The user is exploring this topic as part of an engineering internship, seeking guidance on heat transfer principles and design calculations. Key considerations include the use of cast steel for the platens, with one grooved plate for steam flow and a cover plate, operating at a maximum pressure of 14 bar. Participants suggest referencing heat transfer textbooks and highlight the importance of calculating heat transfer coefficients and flow dynamics. The conversation also touches on the potential risks associated with using steam compared to oil heating methods.
sriram123
Hi all,
I'm looking for design of steam platens for Rubber curing presses.The steam platens heat the green rubber article while curing.Other mediums such as oil,induction heating are also available,but I'm more interested in design of steam platens.
There is one patent available in google patents
http://www.google.com/patents/US5173308
I'm doing my second year engineering and I have some basic knowledge in thermodynamics and fluid dynamics.I'm doing an internship and the company wants me to explore this.
What I need to know is how the steam flow path (the width and height) and the pattern of the path is determined.
Any references or some book citation would be of great help...
Thanks in advance
What material are you planning to use and what is the required temperature? Also, is there a source of pressurized steam for use?
The platen material will be cast steel (IS 1030).There will be two plates.A grooved plate and a covered plate.The grooved plate will be having the steam flow path.The cover plate will be welded to the grooved plate so that they form a passage.The steam will have a max. pressure of 14 bar.It will be super heated.
Ok I'll just give you an idea on how to do it..
Heat will be transferred to the platen surface from the steam initially by convection and then conduction. Knowing the heat transfer coefficients, the required temperature and the mass flow rate of steam, you'll have to design the width of the grooves and the thickness of the plate. The plate of importance is the one one which is used in rubber curing.
I think there will be lot of calculations involving Reynolds number, Prandl number, etc. Check out a book on Heat transfer and check forced convection.
Did it help?
You my want to consider heated oil. The injection mould industry has standard heaters configured for this.
With oil you will be dealing with pressures in an uncompressible liquid of a few bar rather than steam at 14 bar - which may be explosive or BLEVE in a catastrophic failure.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
