Designing a shade sail. Help with load analysis.
The discussion focuses on calculating the peak tension in a shade sail for a design project involving a mechanism to tension the sail between four posts. The largest sail measures 8m x 8m, with a material density of 0.5 kg/m², and is designed to have a 250mm sag during installation. The user seeks methods to approximate maximum load, considering the sail as a point mass on two strings, while acknowledging that this may overestimate actual tension due to angle differences. There is debate about modeling the sail as a uniform weight versus a variable load, with one participant noting the successful completion of the design assignment with a high score. The conversation emphasizes the importance of accurate load analysis for structural integrity.
rieuk
I have to develop a mechanism with which to tension shade sails (its basically material tensioned between four posts to provide shade). I've got the mechanism going, but for the failure analysis, I need to calculate the peak tension in the shade sail. This is my information:
1. Largest shade sail is 8m x 8m. Heaviest sail material has density of 0.5 kg/m^2
2. During installation, one corner of the sail will be attached to its support pole, and the diagonal corner will be tensioned so that the whole sail is supported with a 250mm sag in the middle.
I just need the peak tension to find out what steel to use in my mechanism to withstand it. The mechanism essentially 'grabs' one end of the sail, and the post, and brings them together so that a shackle can be insterted.
I'm not sure if the teacher gave us fact 2 hinting that the peak tension the mechanism will experience is when only two corners are attached, and that we can use a rope simplification. Anyone who can suggest a good method of approximating the maximum load on the mechanism (peak tension) would receive a great many thanks.
*chirp chirp* ... damn crickets.
To anyone who's interested, I approximated the sail to be a point mass on two strings and then calculated the tension in those strings. I asserted that this tension will be an over approximation to the actual tension because the angle of elevation of the tension force in the approximation model is lower than in actuality.
No haynewp, in case you did not notice, it is a SHADE SAIL (square shaped piece of fabric/whatever material used for sail) held up by two corners. It clearly can not be modeled as a uniform weight (it is a variable load as you go along the sail - quadratically if I remember correctly..or maybe linear). If I approximated it by this model, it would be hard to tell whether it was an over/under approximation.
In any case, I got 18/20 for this design assignment, so I'm pretty happy with that. No thanks to anyone here...
People will help if they can, no reason to be snobby about it. Good job on the project.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
