Designing an orifice plate to increase the pressure in a pipe
To design an orifice plate that increases pressure in a pipe at 3.013 bar absolute pressure, the pressure ratio indicates choked flow. Two equations are available for calculating flow through an orifice: one for choked flow and another for non-choked flow. The choice of equation depends on the flow conditions, which are determined by the pressure and gas properties of air. Given the known pressure, gas properties, and flow rate, the only unknown is the orifice diameter. Proper application of the choked flow equation will yield the required diameter for the orifice.
shekarharsha
I am doing an experiment , where air is flowing through a square pipe of 95mm x95mm cross section with a mass flow rate of say 500slpm, now i want to chock the flow in order to increase the pressure in the pipe up to 4bar (absolute) max by using an orifice plate at the end of the pipe. now i want to find the orifice diameter, for which i get the desired pressure in the pipe.
now i know for chock condition : P/Po<.528
where p- 1 atm
Po- 3+1.01325=4.013bar(absolute) inside pipe
say for 3.013bar absolute pressure
pressure ratio :
P/Po = 14.7psi/43.707psi = 0.33
which means its chocked flow
now i want to find diameter or area of orifice :
so could anyone help me
There are two orifice flow (search the term) equations for flow through an orifice. One is for choked flow, the other for non-choked flow. The criteria that you used in your post tells you which equation to use. You know the pressure, gas properties of air, and flow rate, and the only unknown is the orifice diameter.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
