Designing Audio Amplifier with BJT and MOSFET Components
The discussion focuses on designing an audio amplifier using both BJT and MOSFET components, specifically seeking a schematic for a Class AB, D, G, or T amplifier. The user mentions a powerful 5000W amplifier utilizing 2SC5200 and IRFP250 transistors, powered by dual voltage supplies. They express interest in amplifiers that operate with switching technology and complementary configurations. The user has found various resources online but is looking for specific power amplifier schematics that incorporate both BJT and MOSFET components. The conversation highlights the need for clarity on the role of an IC in controlling the switching operation within these amplifiers.
..::D::..
Hi, I'm new here. can somebody put here an a schematic of Class AB, D,G or T. I need an audio amplifier that work with bjt and mosfet simultaneously, i think that kind of amplifier is class g, but I'm not sure,for example i saw an 5000w amplifier with 2sc5200 and his pnp pair working with irfp250 with his pair, the power supply was 80V -0- 80V and 70V-0-70V.
That amplifier works with switching, i think.
Thanks for your help
P.D: my english isn't well Sorry I'm learning
What kind of audio websites have you tried looking through so far? I googled audio amp tutorial power schematic, and got lots of hits:
http://www.google.com/search?hl=en&lr=&q=audio+amp+tutorial+power+schematic
For example, here's a website with links to lots of pages with schematics:
http://dmoz.org/Science/Technology/Electronics/Reference/Circuit_Archives/
And here's a book resource from Amazon that you might want to check out:
Thanks for your help, but i need specially schematics of Power amplifiers, my need is an schematic of some amplifier that work with switching with mosfets an Bjt, better if is complementary.
i will check that links.
Thanks
i saw one amplifier with this system, with an a IC, the reference i don't know, one comrade said that this is an a regulator, or can be a pulse modulator, i think what that IC control the switching operation with the mosfets and Bjt's
My english Sucks!
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
