Designing microgenerator with Ansoft Maxwell
The discussion focuses on designing a magnetic spring for an energy harvester using Ansoft Maxwell, with specific challenges related to the force vs. displacement curve of the moving magnet and calculating output power from the winding. The goal is to achieve the highest linearity in the force-displacement curve to enhance power output. A user seeks assistance as a beginner with Ansoft Maxwell, highlighting the need for guidance on these technical aspects. Another participant suggests a relevant paper that could provide insights into designing a linearized magnetic spring. The conversation emphasizes the importance of optimizing the design for effective energy harvesting.
jahedcuet
I am designing an energy harvester consisting of a magnetic spring.
The figure is given in the attachment.
I have done the magnetostatic analysis (using Ansoft Maxwell 2D). But, now I am facing problem with -
  • Force vs displacement curve of the moving magnet
  • To calculate the output power (Voltage+current) from the winding arround the magnetic spring
I need to design a magnetic spring with highest linearity (linear force-displacement curve) and to get better power output from the winding.
I am beginner with ansoft maxwell. Can anyone help me in this regard?
Thanks
I have also a similar problem with Ansoft Maxwell !
This paper 'Design of a linearized magnetic spring for body-worn inertial energy harvesters' may help you out.
Thanks.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
