Desulfurization, Removing ammonia problem
  • Thread starter Thread starter sawhai
    Ammonia
The discussion focuses on calculating the amount of limestone (CaCO3) and ammonia (NH3) needed to remove sulfur dioxide (SO2) and nitrogen oxides (NOx) from the combustion of West Virginia coal. The coal's composition is detailed, and the combustion process is assumed to be complete, producing specific gases. The user has balanced the reaction for sulfur removal but is uncertain about the next steps in determining the lower heating value (LHV) of the coal in kg. The conversation emphasizes the need for accurate calculations to ensure effective flue-gas desulfurization and selective catalytic reduction. Overall, the thread revolves around the technical aspects of coal combustion and emissions control.
sawhai
A West Virginia coal burned in a steam generator has the following mass analysis: carbon 75.0%, oxygen 6.7%, hydrogen 5.0%, water 2.5%, sulfur 2.3%, nitrogen 1.5%, ash 7.0%.
How much limestone, CaCO3, in kg/day is needed to remove 96% of the SO2 produced from combustion of the coal, using wet scrubbing flue-gas desulfurization, if the boiler fired using this coal produces combustion heat at a rate of 150 kW? Assume complete combustion of the coal’s carbon, hydrogen and sulfur content to CO2, H2O, and SO2 respectively.
How much ammonia, NH3, in kg/day is needed to remove 85% of the nitrogen oxides produced from combustion of the coal, using selective catalytic reduction, if 20% of the nitrogen content of the coal is converted into equal molar amounts of NO and NO2 during combustion? Assume that oxidation of the nitrogen content of the coal does not contribute to its heating value.
you may assume that the coal is burned with 25% excess air and that the water produced from the coal combustion exits with the flue gas as a vapor; i.e. use the lower heating value of the coal in your scaling analysis. This will give you an upper bound on the rates at which the acid gases are produced in the combustion stack gas, and corresponding upper bounds on the rates at which limestone and ammonia must be supplied to the FGD and SCR units to remove these compounds from the flue gas to the specified treatment levels.
caco3+so2->caso3+co2
I wrote the reaction equation and balanced it and ended up with this:
6.244 C+2.48 H2+0.0717 S+ 0.2093 O2 + 0.053 N2+ 7.5557 O2+ 0.1387 H2O --->6.244 CO2+ 2.6187 H2O+ 0.0717 SO2 + 32.8591 N2
I am not sure what to do next.
Thanks
I was able to find the LHV of the coal in KJ/kmol. Now how can I use this value to find the kg of the coal in another word the LHV in KJ/kg without knowing the molecular mass of the coal?
Thread 'PLL - How to find all the gains of a PI corrector and fix Ki ? MATLAB'
Hello everyone, it's not really for my homework (because I'm not at school anymore) but I'm new and I don't know how to start a new forum. I've never done automatic before and I need help. I have a 2nd ordre PLL on MATLAB, with an NCO and a PI corrector; the PLL works via the Mid/End algorithm (that's part is ok). I need to find the link between the theoretical formulas and their values in the code to find the value of the gain Ki, and possibly that of Kp if it's not correct. Unfortunately...
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
