Detect the presence of short-range UWB signals
  • Thread starter Thread starter raymond0517
    Detection
Ultra Wideband (UWB) radar systems operate between 3GHz and 10GHz, making them challenging to detect with standard spycam detectors, which typically only cover frequencies from 1.2GHz to 5.8GHz. While some UWB signals may be detectable, the specific applications and uses of these signals remain undetectable unless one is very close to the transmitter. The prevalence of Wi-Fi and other electronic devices complicates detection, as signals can reflect off various surfaces, leading to confusion with other sources. Additionally, constructing UWB systems is relatively easy for individuals with an electronics background, making covert monitoring feasible. Ultimately, the complexity of UWB radar necessitates advanced equipment to effectively track multiple moving objects through various materials.
raymond0517
Ultra Wideband (UWB) RADAR systems discharge signals over a broad range of frequencies which is between 3GHz to 10GHz as compared to the conventional RADAR systems and remain extremely difficult to detect.
an excerpt from page 2 of https://eudl.eu/pdf/10.4108/eai.7-9...systems utilize,received at the receiver side.
Will the normal spycam detector be able to detect the presence of UWB signals penetrating through the common wall?
YES, to some of the UWB signals, and NO, to what the signals are being used for.
Spycam cannot detect all of the band from 3GHz to 10GHz.
Spycam detects only from 1.2GHz to 5.8GHz.
There is so much Wi-Fi about, that you will detect signals reflected off all sorts of scatterers, wherever you look. You will also detect mobile phones and microwave ovens operating in your vicinity.
You would need to be within a metre or two of a transmitter to detect and move in on it. If it was on the other side of a property wall, you would not know what it was being used for, unless you gained access to that space, and found the rack of computers, radio equipment, and antennas, needed to implement UWB radar.
Likes russ_watters and raymond0517
Thank you Baluncore for the answer.
https://novelda.com/ultra-low-power-sensor
with many high-tech boards easily available, a person with an EEE background can easily assemble a few Arduino-embedded systems concealed under some fixtures on the ceiling (e.g. clock, decorative..), monitoring the movement of the occupant living above it becomes very difficult to prove the intrusion.
raymond0517 said:
with many high-tech boards easily available, ...
Movement detectors, based on microwave reflection, are trivial, and cost less than $5.
A UWB movement detector, that detects only range, is also simple.
UWB radar is very complex because it must track range and direction to several moving objects, through walls made of different materials.
It takes four people to monitor the activity of one person. It is usually not worth the effort, since it is more efficient to eliminate the threat from the situation.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
