Detecting induced electric fields in the ocean
Induced electric fields in the ocean due to moving ions in ocean currents through the Earth's magnetic field are theoretically possible, but the presence of equal numbers of positive and negative ions in seawater would likely cancel out any significant effects. A simple voltmeter setup in the ocean may not effectively detect these fields, particularly for tsunami detection, as distinguishing between normal waves and tsunamis would be challenging. Tsunamis have long wavelengths and small amplitudes offshore, making them difficult to identify with such methods. Current tsunami warning systems rely on pressure sensors on the sea floor rather than electric field measurements. The concept of measuring ionic motion may have potential applications in biomedicine and neuroscience.
royzizzle
Hi everyone:
Since there are many ions in ocean water, and these ions are carried by ocean currents, and they are moving through the Earth's magnetic field, by the electromagnetic induction laws, wouldn't there be a induced electric field in the ocean?
if i want to detect this electric field, would all i need be a piece of conducting wire connected to a very sensitive voltmeter and then place it in the ocean?
p.s: couldn't this be used as a very sensitive tsunami detector? when a tsunami wave passes through, there would be an increase int the speed of conductors.
No.
An interesting idea, but there are equal numbers of positive and negative ions in sea water, so any effects would cancel out.
here is the composition of seawater according to wikipedia:
Component Concentration (mol/kg)
H2O 53.6
Cl− 0.546
Na+ 0.469
Mg2+ 0.0528
SO2−
4 0.0282
Ca2+ 0.0103
K+ 0.0102
CT 0.00206
Br− 0.000844
BT 0.000416
Sr2+ 0.000091
F− 0.000068
from inspection, it can be seen that seawater has slightly more negative ions than positive.
edit: more positive than negative, but only a small amount: .00227moles/kg
The main salt in sea water is Sodium Chloride which dissociates as follows:
NaCl → Na + + Cl -
giving equal numbers of positive and negative ions.
The other salts do the same thing when they dissociate.
There may be more Cl - ions because more than one Chloride formed the original salt mixture.
The list doesn't give H + and OH - ions which would be considerable unless the seawater was completely neutral.
royzizzle, measuring fluid motions by monitoring the electric fields of ions in the fluid seems like a good idea. The charged particles do move through the earth’s magnetic field and, of course, they do obey induction laws. Using the basic laws of physics to create measuring devices is always a sure path to new and innovative ideas.
As for a tsunami detector, this mechanism probably would not be viable. If the sensitive voltmeter was immersed in the ocean to measure fluid motion it may be difficult or impossible to discriminate between normal ocean waves and a passing tsunami wave. Here are a few excerpts from the Wiki tsunami page:
“Tsunami waves do not resemble normal sea waves, because their wavelength is far longer. Rather than appearing as a breaking wave, a tsunami may instead initially resemble a rapidly rising tide, and for this reason they are often referred to as tidal waves. Tsunamis generally consist of a series of waves with periods ranging from minutes to hours, arriving in a so-called "wave train".[4]
Tsunamis have a small amplitude (wave height) offshore, and a very long wavelength (often hundreds of kilometers long, whereas normal ocean waves have a wavelength of only 30 or 40 metres),[22] which is why they generally pass unnoticed at sea, forming only a slight swell usually about 300 millimetres (12 in) above the normal sea surface. They grow in height when they reach shallower water, in a wave shoaling process described below. ”
http://en.wikipedia.org/wiki/Tsunami
Now, it may be useful to read up on how tsunami warning systems are now being implemented around the world. Basically, they measure the increase in pressure caused by the passing tsunami wave using sensors on the sea bottom. See:
http://www.tsunami.noaa.gov/warning_system_works.html
http://nctr.pmel.noaa.gov/Oceans99/index.html
http://www.ndbc.noaa.gov/dart/dart.shtml
Observation: Maybe your basic idea of measuring ionic motion would find useful applications in biomedicine where measuring blood and urine flows is important. And what about in neuroscience, where minute ionic charges are moving around our nervous systems and inside our brains? I hope you are keeping a notebook with your ideas.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
