Determination of time-dependent coefficients (QM)
Aeon
Hi,
I am trying to solve the following equation:
\Psi(r,t) = \sum_n C_n(t) e^{-i E_n t} \psi(r)
to find the C_n(t)s.
The system I am modeling is benzene. I can, by Hückel's method, determine the time-independent solution. The apparently obvious transition from time-independent coefficients to time-dependent coefficients is troubling me. A simple plot of the squared coefficients indicates that my electron density vanishes, which is indicative of error.
I'm wondering how is the proper way to solve for the time-dependent coefficients...
Did you leave off a subscript? If you meant to write ψ(r,t) = ∑ Cn(t) exp(-iEnt) ψn(r) where the ψn(r)'s are orthonormal, then
∫ψ(r,t) ψn(r) dr = Cn(t) exp(-iEnt), which gives you Cn.
I forgot a subscript, you are right.
Also, the problem was that my vectors were not orthogonalized. Thanks!
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
