MHB Determine all postive integer k
  • Thread starter Thread starter anemone
    Integer
The discussion centers on determining positive integers \( k \) for which the function \( f(k) = \left\lfloor{\dfrac{k}{\left\lfloor{\sqrt{k}}\right\rfloor}}\right\rfloor \) satisfies \( f(k) > f(k+1) \). A key point made is that for \( k = n^2 + a \) where \( 0 < a < 2n \), the function can be expressed as \( f(k) = n + \left\lfloor{\dfrac{a}{n}}\right\rfloor \), indicating that \( f(k) \) is non-decreasing. This suggests that the conditions for \( f(k) > f(k+1) \) may be limited. The conversation emphasizes the simplicity of proving this property, indicating that the analysis is straightforward. Overall, the focus is on the behavior of the function and the specific conditions under which it decreases.
anemone
MHB
POTW Director
Determine all positive integers $k$ for which $f(k)>f(k+1)$ where $f(k)=\left\lfloor{\dfrac{k}{\left\lfloor{\sqrt{k}}\right\rfloor}}\right\rfloor$ for $k\in \Bbb{Z}^*$.
Mathematics news on Phys.org
if k+1 is not a perfect square then the floor of square root of k and k+ 1 are same so
f(x) < f(x+1)
so we need to look at k+1 being a perfect square say $n^2$
$f(k) = \left\lfloor\dfrac{n^2-1}{n-1}\right\rfloor= n + 1$
$f(k+1) = \left\lfloor\dfrac{n^2}{n}\right\rfloor= n$
so k is of the form $n^2-1$ for $n\gt 1$
f(x) < f(x+1)
Hey kaliprasad, thanks for participating and your answer is correct! I think it might be necessary(?) to prove that for $k=n^2+a$ with $0<a<2n$,
$f(k)=\left\lfloor{\dfrac{n^2+a}{n}}\right\rfloor=n+\left\lfloor{\dfrac{a}{n}}\right\rfloor$ which is non-decreasing.
But then this is an easy proof, so, there is no big deal here.:)
Hello Anemone,
Both are effectively same as $k= n^2+ a$ with $0\lt a\lt2n$ is same as k+1 is not perfect square and I have mentioned that numerator is increasing and denominator is constant and I should have said $f(x) \le f(x+1)$ instead of $f(x) \lt f(x+1)$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
