MHB Determine co-ordinates of points B?
  • Thread starter Thread starter ai93
    Points
The discussion revolves around finding the coordinates of point B, where the line with the equation y=2x+11 intersects with the line y=x+8. To determine point B, the two equations are set equal, leading to the solution x=-3 and subsequently y=5, giving the coordinates of point B as (-3, 5). Additionally, the discussion touches on calculating the distance between points A and B and finding the gradient between them, with the slope calculated as 2. The necessity of using the distance formula is clarified, as it relates to finding the length of the segment between points A and B.
ai93
I have an equation of a line question
a) Find the equation of the straight line with gradient 2 passing through point A (-4,3)
I worked out the equation of the line, which is, y=2x+11.
But having trouble with question b) and c)
b) if the line in part a) intersects the line y=x+8 at point B, determine the co-ordinates of point B.
c) Find
i) the length
ii) the gradient
Mathematics news on Phys.org
a) This is the correct line. (Yes)
b) Okay, you have two lines:
$$y=2x+11\tag{1}$$
$$y=x+8\tag{2}$$
To find the coordinates of point $B$, where the two lines intersect, you must solve the simultaneous system above. Since we have both lines in function form, we can just equate the two:
$$2x+11=x+8$$
Solve this for $x$, and then substitute the resulting value for $x$ into either (1) or (2) to get the $y$-coordinate.
For part c), I am assuming you are to find the distance between $A$ and $B$, and the gradient or slope between the two points.
Distance formula:
$$d=\sqrt{\left(x_2-x_1\right)^2+\left(y_2-y_1\right)^2}$$
Slope formula:
$$m=\frac{\Delta y}{\Delta x}=\frac{y_2-y_1}{x_2-x_1}$$
Can you proceed?
$$y=2x+11\tag{1}$$
$$y=x+8\tag{2}$$
$$2x+11=x+8$$
Distance formula:
Slope formula:
Can you proceed?
Thanks!
$$2x+11=x+8$$
$$2x-x=8-11$$
$$\therefore x=-3$$
sub $$x=-3 into y=2x+11$$
= y=5
for c) Why is finding the distance necessary? Since we have to use the gradient/slope formula?
Nevertheless
m=$$\frac{5-3}{(-3)-(-4)}$$
m=2
:D
Yes, everything looks correct. :D
You asked why do we need the distance formula...well, you originally posted that you need the length, and I assume you are being asked to find the length of line segment $\overline{AB}$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
