Determine force exerted on rod & reaction
In summary, the conversation discussed a problem involving a conveyor system and a 300-mm rod lodged between two vertical panels. The acceleration of the system to the left was given and the task was to find the force exerted on the rod at point C and the reaction at point B. Through drawing a free body diagram and using the equations of sum of forces and sum of moments, forum users were able to provide the correct answers of 3.43N at 20 degrees above the horizontal and 24.4N at 73.4 degrees above the horizontal for these respective points.
JJBladester
A conveyor system is fitted with vertical panels, and a 300-mm rod AB of mass 2.5kg is lodged between two panels as shown. Knowing that the acceleration of the system is 1.5m/s2 to the left, determine (a) the force exerted on the rod at C, (b) the reaction at B.
Answers:
(a)3.43N at 20 degrees above the horizontal (1st quadrant)
(b)24.4N at 73.4 degrees above the horizontal (2nd quadrant)
[tex]\sum F_x=m\bar{a}_x[/tex]
[tex]\sum F_y=m\bar{a}_y[/tex]
[tex]\sum M_G=\bar{I}\alpha[/tex]
Where [itex]G[/itex] is the center of mass and [itex]\bar{x}[/itex] and [itex]\bar{y}[/itex] are the x and y coordinates of G.
Draw a free body diagram:
Sum of the forces equations:
[tex]\sum F_x=Ncos(20)-Bcos(70)=ma[/tex]
[tex]\sum F_y=Nsin(20)-mg+Bcos(70)=0[/tex]
That's all I can think of and I know that assuming B's reaction is at 70 degrees is wrong because the answer states that it is at 73.4 degrees above the horizontal (2nd quadrant).
What is wrong with my FBD?
Thank you for sharing your thoughts and attempt at solving this problem. Your free body diagram and equations seem to be correct. However, there may be a minor mistake in your calculation for the reaction at B. Instead of using the angle of 70 degrees, you can try using the angle of 20 degrees, which is the complementary angle to 70 degrees. This should give you the correct answer of 73.4 degrees for the reaction at B. Keep up the good work!
Related to Determine force exerted on rod & reaction
1. What is the formula for determining force exerted on a rod?
The formula for determining force exerted on a rod is F = EAΔL/L, where F is the force, E is the modulus of elasticity, A is the cross-sectional area, ΔL is the change in length, and L is the original length of the rod.
2. How do you calculate the modulus of elasticity for a rod?
The modulus of elasticity for a rod can be calculated by dividing the stress by the strain. The stress can be found by dividing the force by the cross-sectional area, and the strain can be found by dividing the change in length by the original length.
3. What is the reaction force on a rod?
The reaction force on a rod is the equal and opposite force exerted by the support or pivot point on the rod to keep it in equilibrium.
4. Can the reaction force on a rod be negative?
No, the reaction force on a rod cannot be negative. It will always be equal in magnitude but opposite in direction to the force exerted on the rod.
5. How does the length of a rod affect the reaction force?
The longer the rod, the higher the reaction force will be. This is because a longer rod will experience a greater change in length for the same amount of force applied, resulting in a higher modulus of elasticity and therefore a higher reaction force.
