MHB Determine if you have enough info to figure a side
  • Thread starter Thread starter clhrhrklsr
    Figure
To determine if there is enough information to solve the problems presented, the discussion focuses on two scenarios involving a ladder and a triangle. In the first scenario, a 15-foot ladder's base distance from the wall is represented by 'a', with the range specified as 0<a<15. The second scenario involves a right triangle with a 90-degree angle, a 67-degree angle, and a height of 10 feet, where the slope (side C) can be calculated using trigonometric ratios. The calculation involves using the tangent function to find the length of side C, resulting in approximately 23 feet and 6.6875 inches. The discussion emphasizes the application of trigonometry to derive the necessary dimensions from the given information.
clhrhrklsr
I have a couple of practice problems similar to ones I've seen before.
Could anyone tell me how to figure these? I don't even know where to begin on solving these. How do you begin to determine if you have enough information.
Thanks in advance for any help! View attachment 2802
Mathematics news on Phys.org
No.
0<a<15
Suppose you have a 15 foot ladder to place against a wall. 'a' represents the distance of the base from the wall.
RLBrown said:
No.
0<a<15
Thanks! Okay, now the 2nd question on my attachment. Is there enough information given to find the length of side C? You are given a 90 degree angle, a 67 degree angle. You are also given a height of 10'-0". Side "C" is the slope of the triangle. Is there enough information given in this triangle to find side C?
Yes there is. What trigonometric ratio do you think you will need to use?
Code:
Please correct me if I'm wrong.
\tan\left({67}\right) = \frac{AB}{BC}
AB = 10 x \tan\left({67}\right)
\tan\left({67}\right) = 23.5585
If you need to convert the decimal to feet and inches, you would get the following-
23.5585=23'-6\frac{11}{16}"
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
