Determine original velocity (kinematics)
To determine the original velocity of a ball hit at a 3-degree angle that reaches a height of 0.330m, the equations d=Vot + 1/2at^2 and Vf=Vo+at are relevant. The vertical component of the initial velocity can be expressed as Voy = Vosin(3 degrees), while the horizontal component is Vox = Vocos(3 degrees). To find the time to reach maximum height, the relationship h(max) = Vy = 0 can be used, leading to the equation Voy = -at. Another approach involves using a kinematic formula that relates distance and velocity for accelerated motion. Ultimately, combining these equations will yield the original velocity of the ball when it left the racket.
Josh930
if a ball hit by a racket at an angle of 3 degrees reaches a height of .330m at its trajectory, how fast was the ball moving when it left the racket?
d=Vot + 1/2at^2
Vf=Vo+at
Vox = Vocos(3dgres)
Voy = Vosin(3dgres)
h(max)= Vy=0
so Voy= -at?
i think i have to find the time it takes to reach the max height, then I am lost... please help
Josh930 said:
so Voy= -at?
Sure. Now combine that with your first equation (d=Vot + 1/2at^2) and you can solve for the time it takes to reach max height.
That's not the only way to go. You can also invoke another kinematic formula that directly relates distance and velocity for accelerated motion.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
