Determine speed of bar and average frictional force
To determine the speed of the bar after being struck by the falling object, conservation of momentum can be applied, calculating the combined mass and velocity post-collision. The average frictional force exerted by the ground can be found using the equation F = ma, where acceleration is derived from the distance the bar is driven into the ground. The depth of 0.75m can be treated as the distance over which the bar decelerates due to friction. The discussion emphasizes the need to calculate both the speed after impact and the frictional force accurately. Understanding these principles is crucial for solving the problem effectively.
shinchung24
Large metal bars can be driven into the ground using a heavy falling object. What I have here is a 2000 kg falling object and a metal bar of 400 kg. The falling object strikes the bar at a speed of 6.0 m/s. It comes to rest on the bar without bouncing. As a result of the collision, the bar is driven into the ground to a depth of 0.75m
Now, I need to determine the speed of the bar immediately after the object strikes it
and determine the average frictional force exerted by the ground on the bar.
I'm just not sure on how to approach this.
I kind of have an idea of finding acceleration first for the frictional force which is F= ma?
you need to find the force in which will make a item of that mass be driven to that depth. i think you can find depth as the same as distance
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
