Determine the quadrant(s) in which (x, y) could be located
  • Thread starter nycmathguy
Please omit filler like "Let me see." You don't have to write down your every thought, only those that help us understand what you're doing. "Let me see" doesn't fall into this category.You're tacitly assuming that x is nonnegative, which is false for half of the possible numbers.Same problem as above -- the point (-y, y) is in Quadrant II only if y >= 0.At least I gave it a go, right?Yes, it's good to try and work through the problem. Just be careful to only include relevant information and avoid assumptions that may not hold for all cases.
nycmathguy
Quadrants on the xy-plane.
Linear Equations
in which (x, y) could be located.
Chapter 1, Section 1.1
13. x + y = 0, x ≠ 0, y ≠ 0
Let me see.
x + y = 0
I can solve for y.
y = - x
If y is - x, we get the point (x, - x).
This leads me to see a point in quadrant 4.
I can also solve for x.
If I do so, I get x = - y.
This leads to the point (-y , y), which takes me into quadrant 2.
I say the answer is quadrants 2 and 4.
You say?
(x, -x) doesn't necessarily have to be in quadrant 4. (Should x be positive?)
Likes PeroK
nycmathguy said:
Homework Statement:: Quadrants on the xy-plane.
Relevant Equations:: Linear Equations
Let me see.
x + y = 0
I can solve for y.
y = - x
This is fine. Can you draw the graph of this function?
Are you asking me to draw y = x and y = -x on the same xy-plane?
Only ##y = -x##, which is the equation you have.
This is not a homework statement.
Not an equation. If you can't think of any relevant equation, just leave it blank - don't just put something in for the sake of doing so.
This is the homework or problem statement.
Let me see.
nycmathguy said:
x + y = 0
I can solve for y.
y = - x
You say?
Likes berkeman
Can you provide an example of a HW Statement and Relevant Equations for those two categories? I have been corrected over and over and over again since joining this site.
Is my answer right or wrong?
For this thread:
in which (x, y) could be located for the line x + y = 0, x ≠ 0, y ≠ 0.
None
Your answer is correct -- the line is in quadrants II and IV.
In another of your threads, about the diagonals of a parallelogram, these sections might look like this:
Prove that the diagonals of a parallelogram intersect at their midpoints.
Midpoint of the line segment from (a, b) to (c, d): ##(x_m, y_m) = (\frac{a + c}2, \frac{b + d} 2)##
Likes nycmathguy
Your answer is correct, but as @Quantour pointed out in post #2, your working was not right. And, you really took a long way round. When you have: $$y = -x$$ you should see that is the equation of a straight line through the origin. To graph a straight line you need only two points. We have the origin: ##x = 0, y = 0##. We might as well take ##x = 1## for our second point, which gives ##x=1, y = -1##.
That gives us a line through the second and fourth quadrants.
Likes nycmathguy
Can you please provide an example of a Homework Statement and an example of Relevant Equations for those categories?
I already did this in post #9.
Tale the problem about find two missing numbers.
Here it is again:
Two numbers add up to 72. One number is twice the other. Find the numbers.
The HW Statement:
Find the numbers.
What would be the Relevant Equations in this case?
The HW Statement:
Find the numbers.
That's pretty vague. An improvement would be
Find two numbers whose sum is 72, with one number being twice the other.
You could leave that section empty.
This is what I'm talking about. Sometimes it is best to leave that section blank and for some questions it makes to complete the section.
What about for the following question?
I know how to solve the following equation. This is just an example.
Solve x + 5 = 10 for x.
Homework Statement:
Solve for x.
Relevant Equations:
Linear Equation
Is this right?
The line above would be a good homework statement, but this problem is soooo simple it would hardly be worth posting a question about it.
Likes nycmathguy
Moving on...
Related to Determine the quadrant(s) in which (x, y) could be located
1. What is meant by "quadrant" in this context?
A quadrant is a section of a coordinate plane that is divided by the x-axis and y-axis. There are four quadrants in total, labeled as I, II, III, and IV, starting in the top right and moving counter-clockwise.
2. How do I determine which quadrant a point is located in?
To determine the quadrant of a point (x, y), you need to look at the signs of the x and y values. If both x and y are positive, the point is in quadrant I. If x is negative and y is positive, the point is in quadrant II. If both x and y are negative, the point is in quadrant III. And if x is positive and y is negative, the point is in quadrant IV.
3. Can a point be located in more than one quadrant?
No, a point can only be located in one quadrant at a time. Each quadrant is a distinct section of the coordinate plane.
4. How does determining the quadrant of a point help in graphing?
Determining the quadrant of a point can help you accurately plot the point on a graph. It also helps you understand the relationship between the x and y values of the point, as well as its position relative to the origin.
5. Is there a specific order in which the quadrants are labeled?
Yes, the quadrants are labeled in a counter-clockwise direction, starting with quadrant I in the top right corner and moving to quadrant IV in the bottom right.
