Determine the Transition Wavelength
The discussion focuses on calculating the transition wavelength for the OH molecule from the ground state to the first rotationally excited level, which is 120 K above the ground state. Participants clarify that the mainline frequencies of 1.6 GHz and 6 GHz indicate energy differences between sub-levels, not direct transitions. The correct transition energy between the J=5/2 and J=3/2 levels is estimated at approximately 85 cm^-1, leading to a wavelength of about 119.2 µm. It is emphasized that the energy level diagram is crucial for accurate calculations, and the temperature of 120 K can be used to derive the energy and corresponding wavelength. Understanding these concepts is essential for determining the transition wavelength accurately.
Samuel Williams
Hi all, the question is as follows:
1. Homework Statement
From the energy level diagram for OH in the study guide, it can be seen that the first rotationally
excited level of OH (23=2 J =5\2) lies 120 K above the groundstate. What is the wavelength of radiation associated with a transition between the groundstate and the first excited level?
This is an energy level diagram that contains the relevant wavelengths, the numbers in blue are the transition wavelengths, which is what I require.
I would just like to know how to actually calculate the wavelengths.
The difference in frequencies is, for example from J = 5/2 to J = 3/2, 4365MHz where the main line frequencies of 1665MHz and 6030MHz are used. However, this corresponds to a wavelength of 0.068m, which is far off of the 0.000119m actual value. I suspect that I am calculating it incorrectly, I am unsure how to actually do it.
What do you mean by the "mainline frequencies"? Are they the 1.6 GHz and 6 GHz marked on the diagram? These are not the energies of the 3/2 and 5/2 levels; they are the energy differences between the + and - sub-levels of these levels. A wavelength of 119.2 µm corresponds to 2517 GHz.
What is meant by the statement "the first rotationally excited level lies 120 K above the groundstate"? How might you use this information to calculate the answer?
Likes nrqed
Yes, the mainline frequencies are the corresponding 1.6GHz and 6 GHz as seen. They are referred to as mainline because F = constant for their transitions. Are you referring to thermal excitation, or something with regards to blackbody radiation such as Wien's law? I don't think that is applicable, although I could be wrong. I am frequently afterall
EDIT: I just realized that mcj123 had already made the same comments.
You cannot combine the 1665 MHz and the 6030 MHz to get the transition J=5/2 to J=3/2. The 1665 MHz gives the splitting between the J=3/2 lines (the more precise values are given in the graph) while the 6030 MHZ gives the splitting between the J=5/2 lines. This tells us nothing about the transition 5/2 to 3/2. The energy of transition between the J=5/2 and the J=3/2 is approximately ##85 cm^{-1}## if we use the vertical axis to estimate the value, which gives a wavelength of ##0.000118## cm. But it is hard to read precisely on the graph since no graduation is shown. However, it seems that the wavelength in ##\mu m## is directly written on the graph, it is the 119.2 number written there.
Note that if you convert 1GHz to the unit ##cm^{-1}##, you will get something tiny. The graph is not drawn to scale, the splittings wishing the J=5/2 lines or within the J=3/2 lines are tiny tiny compared to the separation between J=3/2 and J=5/2.
I assume "the first rotationally excited level lies 120 K above the groundstate" means that 120K is the temperature at which E = kBT. Hence you can work out E, and hence the wavelength.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
