Determine the translational speed of the cylinder
The discussion focuses on determining the translational speed of a solid cylinder rolling down an inclined plane. The approach involves equating gravitational potential energy (mgh) to the sum of translational and rotational kinetic energies. The derived formula for the translational speed at the bottom of the incline is v = √[(4/3)gh]. Participants confirm that this method is correct and suggest an alternative approach involving effective mass and gravity, although it may not be favored by examiners. The solution emphasizes the relationship between potential energy and kinetic energy in rolling motion.
k-rod AP 2010
36
A solid cylinder w/ mass m, radius r, and rotational inertia 1/25mr2 rolls without slipping down an inclined plane. THe cylinder starts form rest at height h. The inclined plane makes an angle θ w/ the horizontal.Determine the translational speed of the cylinder when it reaches the bottom of the inclined plane.
v=velocity
ω=angular speed
I=moment of inertia
U=gravitational potential energy
K=Kinetic Energy
U=Ktranslational + Krotational
mgh=(1/2mv2) + (1/2Iω2)
mgh=(1/2mv2) + (1/2 (1/2mr2)(v2/r2))
gh=(v2/2) + (v2/4)
gh=(2v2/4) + (v2/4)
gh= (4/3)v2
v2=(4/3)gh
v= √[(4/3)gh] would this be the correct procedure to solve this?
hi k-rod AP 2010! :smile:
v2=(4/3)gh
(i assume you meant rotational inertia 1/2 mr2 ? :wink:)
yes, that's the right method and result! :smile:
(btw, another way is to say the "rolling mass" is I/r2, = m/2, so the total "effective mass" is 3m/2, so the "effective gravity" is 2g/3, so 1/2 mv2 = 2mgh/3 … but i don't think the examiners would like that! :redface:)
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
