Determine torque required to move load
In summary, the electric motor would need to move the load at a maximum speed of 1.8288 m/s in order to apply the necessary torque to move the 100lb object.
lsvaladez
Trying to figure out how much torque an electric motor would need to move a load of 100lbs on a flat surface. The device would use two electric motors attached to a 8 inch diameter wheel (each motor is attached to a 8 inch wheel).
Welcome to PF.
Only the energy needed to accelerate the mass must come from the motor.
What is the maximum speed required?
To enable us to calculate the wheel torque required, we need to know how far the vehicle will travel, and how much time does it have to get there?
A cheaper, low-torque, high-RPM motor could be used if the motor has a gearbox, that would slow the wheel speed and increase the torque available to drive the wheel.
Likes Bystander
Are you using the wheels to drive a conveyor belt carrying a 100 lbf load, or something else, maybe this is a buggy carrying 100 lbf? Either way, acceleration and various forms of friction should be considered to determine the minimum output.
Is this homework? If so, we can move it.
A diagram of what you are trying to do would be very helpful because your description is unclear. If you have no information on rolling friction, you need to provide the necessary information so that we can help you estimate the rolling friction. You need to describe the speed, distance, move time, and acceleration in order to calculate acceleration torque. You need to know the maximum speed in order to properly specify the motor and reducer.
Likes Juanda
Baluncore said:
Welcome to PF.
Hello,
Let’s say the device needs a max velocity of 5mph, and we want it to travel around 30ft in 10 seconds.
I assume you must stop when you get there, and have no brakes, so you will use the motor to brake. That makes the problem symmetrical.
Accelerate for 5 seconds, then decelerate for 5 seconds, to get there in 10 sec. 15 feet in the first 5 seconds, then 15 feet in the last 5 sec.
We know; s = ½ * a * t2 ; so can calculate the acceleration.
a = 2 * s / t2
a = 2 * 15 / 52
a = 30 / 25 = 1.20 ft⋅s-2
The speed limit is 5 mph = 7.333 ft/sec.
What will the velocity be after 5 seconds.
v = 1.2 * 5 = 6 ft/sec.
So it is below the speed limit.
I think I would use SI units for the next bit.
SI units.
Time, t = 5.000 sec
Dist, d = 15' * 0.3048 = 4.572 m
Accel, a = 2 * d / t^2 = 0.3658 m/s/s
Vmax, v = a * t = 0.3658 * 5 = 1.8288 m/s
Mass, m = 100 lb * 0.4536 = 45.36 kg
Force, f = m * a = 16.591 N, (newtons)
Radius, r = 4" = 0.1016 m
Torque = f * r = 1.6856 N.m
Energy = 0.5 * m * v^2 = 75.8535 J, (joules)
Related to Determine torque required to move load
What is torque, and how is it related to moving a load?
Torque is a measure of the rotational force applied to an object. It is calculated as the product of the force and the distance from the point of rotation. For moving a load, torque determines how much rotational force is needed to overcome resistance and initiate movement.
How do I calculate the torque required to move a load?
To calculate the torque required to move a load, you need to know the force needed to move the load and the distance from the pivot point (lever arm). The formula is Torque (τ) = Force (F) × Distance (d). If friction or other resistive forces are involved, these must also be considered in the calculation.
What factors influence the torque required to move a load?
Several factors influence the torque required to move a load, including the weight of the load, the distance from the pivot point, frictional forces, the angle of application of the force, and the mechanical advantage provided by any levers or gears.
How does friction affect the torque required to move a load?
Friction adds resistance to the movement of a load, requiring additional torque to overcome it. The amount of friction depends on the materials in contact, surface roughness, and normal force. To account for friction, you need to calculate the frictional force and add it to the force required to move the load.
What tools or instruments can be used to measure or determine the torque required to move a load?
Several tools and instruments can be used to measure or determine torque, such as torque wrenches, torque sensors, and dynamometers. These devices can provide direct readings of the torque applied to a system, helping to ensure that the correct amount of force is being used to move a load.
