Determine what's in a container
  • Thread starter Thread starter displayname
    Container
To determine the contents of a container with either a battery and resistor or a capacitor, a voltmeter can be used to measure the initial voltage. If the voltage is zero, a capacitor is present; if not, a resistor can be added to assess voltage drop. For a battery, Ohm's law (V = I(R + r)) can be applied by measuring voltage across a known resistor to find the current and then solve for the resistance. For a capacitor, connecting a resistor in series and graphing voltage versus time can help determine capacitance. Multiple resistor values may be needed for accurate results in both scenarios.
displayname
You are given a container with either a battery and a resistor or a capacitor inside it. There is also a positive and negative terminal sticking out of the container.
Without looking inside, how will you determine what is inside the container? Materials include a voltmeter, a voltage vs. time probe, wires and alligator clips, resistors, and batteries.
If it is a batter and resistor, how will you determine the voltage of the battery and the resistance of the resistor? If it is a capacitor how will you determine the capacitance (hint: graph voltage vs. time)?
V=IR
V = Vo(e^(-t/RC))
Find if battery of capacitor:
- attach a voltmeter in parallel to figure out initial voltage
- If there is 0 voltage, you have a capacitor.
- If voltage is not 0, attach a resistor for a second
- Remove resistor then measure the voltage again. If the voltage dropped significantly to 0 or close to 0, you have discharged a capacitor. Otherwise, if the voltage stayed about the same, you have a battery.
In order to confirm you have a capacitor, attach a battery to the circuit. Disconnect battery. See if voltage is not 0.
If you have a battery:
- find voltage by adding voltmeter in parallel
- find resistance by?
If you have a capacitor:
- add a resistor in series (note resistance)
- use the voltage over time probe and graph voltage over time
- get two voltage points and plug into the voltage of capacitor equation to solve for capacitance
Is this method right? How do i find resistance of a resistor? maybe use V = IR, but we don't know I
How will you charge the capacitor if that's what you have?
couldnt you just attach the two ends to the terminals of a battery and then check the voltage to see if the capacitor charged
displayname said:
couldn't you just attach the two ends to the terminals of a battery and then check the voltage to see if the capacitor charged
Yes.
Now, if it's a battery and a resistor, I assume the resistor will be in series with the battery. Connect a known resistance across the terminals of the container. Measure the voltage drop across the resistor. Use Ohm's law to find the current. Do this for a few values of resistance.
Ok. This is my understanding:
So by attaching the voltmeter to the terminals of the container, we find the voltage of the battery (V). Now, we attach a resistor (with resistance r) to the terminals (so the resistor is in series). Let's say the resistance of the resistor attached to the batter is R.
V = I(R+r) -- two unknowns, I and R
Measuring the voltage drop between the known resistance results in solving for I.
Plug in I into the V=I(R+r) and solve for R.
So really we only need to try one resistor but can try multiple resistors to verify answer.
Yes. Also, a particular resistor, r, may not give a very good result for R. If r has a much larger resistance than R, then voltage drop, Vr that you measure across r will be nearly as large as V, the voltage of the battery. Using too small a value for r can also cause problems.
For a capacitor you may also need to use various resistors. Definitely discharge more than once & compare results.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
