Determing Whether A Function Is A Solution To A Differential Equation
In summary, the differential equation given is y' -2ty = 1 and a possible solution is y=e^{t^2}\int^6_0e^{-s^2}ds + e^{t^2}. The integral for this solution can be obtained using integration by parts, but it cannot be expressed in closed form. However, the solution can be verified by differentiating and substituting into the original equation. The term "closed form" refers to being able to express the integral in terms of elementary functions.
Bashyboy
1,421
The differential equation: y' -2ty = 1.
The possible solution: [itex]y=e^{t^2} \int^6_0e^{-s^2}ds + e^{t^2}[/itex].
For the integral, I employed integration by parts:
Let [itex]u=e^{-s^2} \rightarrow du = -s2e^{-s^2}ds[/itex]
and
Let [itex]dv = ds \rightarrow v=s[/itex].
This lead to:
[itex][se^{-s^2}|^t_0 - \int_0^t -2s^2e^{-s^2}ds[/itex]
My first thought was to perform another integration by parts; however, after having run through the process in my mind, this would seem of no avail. What am I missing?
Okay, so the point is you can't put that integral into closed form. Just leave it as it is. What you _can_ do is differentiate is. So what you want to do is simply differentiate your possible solution and put that back into the original differential equation.
How would you define "closed form?"
That function, [itex]e^{-x^2}[/itex] is well known NOT to have any elementary integrand. The "error function", erf(x), used in statistics and probability, is defined to be its integral and tables of the normal distribution are created using numerical integration.
In any case, there is no reason to actually do the integration- since it is a definite integral it is simply a constant. The problem is actually asking you to show that [tex]y(t)= Ce^{t^2}+ e^{t^2}= De^{t^2}[/tex]. where D= C+ 1, satisfies that equation. Differentiate that to find y', put it into the equation and see if the equation is satisfied.
(Note that the problem says "possible" solution.)
I don't think so, Halls. I think he just mis-wrote the first integral. It's supposed to be erf(t) not erf(6). Just look at his later calculations.
Anyway, what Halls said is basically what I meant. 'Closed form' means that you can write the integral in terms of elementary functions.
Okay, if it is in fact supposed to be [itex]y= e^{t^2}\int_0^t e^{-s^2}ds+ e^{t^2}[/itex], then use the "Fundamental Theorem of Calculus to differentiate:
[itex]y'= 2te^{t^2}\int_0^t e^{-s^2}ds+ e^{t^2}(e^{-t^2})+ 2te^{t^2}[/itex]
But "[itex]2t(e^{t^2}\int_0^t e^{-s^2}ds+ e^{t^2})[/itex]" is just [itex]2ty[/itex] and [itex]e^{t^2}e^{-t^2}= 1[/itex].
FAQ: Determing Whether A Function Is A Solution To A Differential Equation
What is a differential equation?
A differential equation is an equation that involves a function and its derivatives. It describes the relationship between a function and its rate of change.
How do you determine if a function is a solution to a differential equation?
To determine if a function is a solution to a differential equation, you must plug the function into the equation and see if it satisfies the equation. This means that the function must make the equation true when substituted for the dependent variable.
What is the order of a differential equation?
The order of a differential equation is the highest derivative present in the equation. For example, a first-order differential equation would have a first derivative, while a second-order differential equation would have a second derivative.
Can a differential equation have multiple solutions?
Yes, a differential equation can have multiple solutions. This is because the solution to a differential equation is not unique and can be represented by a family of functions that all satisfy the equation.
What is a particular solution?
A particular solution is a specific solution to a differential equation that satisfies any initial conditions or boundary conditions given in the problem. It is a single function that represents a specific solution to the equation.
