Determining change of momentum of a tennis ball
To determine the change of momentum of a tennis ball colliding with a wall in a partially elastic collision with e=0.5, one must first calculate the speed after the collision using the coefficient of restitution. The basic momentum equation F.(t2-t1) = P2 - P1 is not applicable here due to the unknown time variables. Instead, the focus should be on the relationship between initial and final velocities influenced by the elasticity of the collision. Understanding these principles is crucial for accurately calculating the change in momentum.
marijo
A tennis ball is thrown perpendicularly to the wall. The ball collides with the wall at p momentum. If its collision is partially elastic where e= 0.5, then its change of momentum is
e= 0.5 which its a partly elastic collision
how do we determine the change of momentum? does it involve the basic equation of momentum; that F.(t2-t1) = P2 - P1
thanks before
welcome to pf!
hi marijo! welcome to pf! :smile:
(try using the X2 icon just above the Reply box :wink:)
no, because you have no idea what the times are! :rolleyes:
you need to use e= 0.5 to find the speed after the collision :wink:
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
