Determining Damping Constant k From Data
  • Thread starter Thread starter Talz1994
    Constant Damping
To determine the damping constant k from the data of a damped pendulum, the user has plotted a graph of amplitude versus turns, which shows an exponential decrease. The theoretical k value calculated is 0.22456, but the user is unsure how to extract this value from the graph. A suggestion is made to transform the y-axis to ln(A_0/A) to linearize the data, which could help in determining k more easily. The user seeks clarification on this method and expresses anxiety about participating in the forum. Understanding how to manipulate the graph is crucial for comparing theoretical and experimental values of k.
Talz1994
i had an investigation
use your data to find the value of k, compare this theoretical number with your data.
- plot a suitable graph so that you can determine k.
A= A_0e^(-kn)
A_0 initial amplitude = 1
hey I am new to the forum and yeh here my question. well i was given the homework getting a set of readings of a damped pendulum bob. i got the readings took an average and then i managed to plot a graph of those readings. i did so and i managed to get a graph which decreases exponentially. now i want to compare my therotical damping constant with my data and i have come stuck.
the y-axis is amplitude, "A" and the x-axis "n" turns
my k value theoretically is 0.22456, but i don't know how to find it from my graph.
should i change my y-axis to ln(A_0/A) that's how one of my friend did it but i don't get it.
sorry for poor english, its my second language, first time using forum. and i tried to follow the rules... :/
anxiously waiting
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
