Determining the direction of electric field lines
In summary: The electric field lines are longer for q1, and the magnitude is proportional to the distance. So the bigger the distance, the smaller the magnitude, as is the case with this sketch?
asilvester635
In general, the field lines points away from the positive charge and toward the negative charge. The answer is letter E, but the second part of the answer says, "the magnitude of q1 is less than the magnitude of q2". Is that because q1 is negative and q2 is positive?
No. The word “magnitude” means “absolute value”, so the sign of the charge is irrelevant.
Besides the direction of the field lines, what else do you notice about them that is different between the two charges?
Several of the field lines from q2 go off the page to infinity, so those are the longest field lines. But that isn’t the distance of interest with field lines.
The E field is proportional to the distance between neighboring field lines, not the distance along a single field line. So look at the distance between field lines immediately surrounding each charge. What do you notice?
I do not follow your question. Still assume, q1 negative and q2 positive and their magnitudes are equal then what do you expect.what features the field lines should have. one is the direction of field lines what another feature is there about these lines. Try to draw or imagine lines for different cases from from |q1| = 0 to
|q1| = |q2|.
Why don't you look at this applet?
https://phet.colorado.edu/sims/html/charges-and-fields/latest/charges-and-fields_en.html
First use one positive and one negative charge. Then try pilling on more of one charge, and then repeat by using the other charge. Figure out for yourself which scenario resembles that you were given in the figure.
Zz.
Related to Determining the direction of electric field lines
What is the purpose of determining the direction of electric field lines?
The purpose of determining the direction of electric field lines is to understand the direction of the electric field at a given point in space. This helps in understanding the behavior of charged particles in an electric field and in predicting the movement of these particles.
How do you determine the direction of electric field lines?
The direction of electric field lines can be determined using a test charge. The direction of the electric force on the test charge will be in the same direction as the electric field at that point. Alternatively, the direction of the electric field lines can be determined by using a compass needle, which aligns with the direction of the magnetic field produced by the electric field.
What factors affect the direction of electric field lines?
The direction of electric field lines is affected by the magnitude and direction of the source charge, as well as the distance from the source charge. The presence of other charges in the vicinity can also affect the direction of electric field lines.
Can the direction of electric field lines change?
Yes, the direction of electric field lines can change depending on the location and arrangement of source charges. In the case of two or more charges, the direction of the electric field lines will be determined by the vector sum of the individual electric fields.
How is the direction of electric field lines represented?
The direction of electric field lines is represented by arrows pointing in the direction of the electric field at a given point. The density of the lines also represents the strength of the electric field, with closer lines indicating a stronger electric field and vice versa.
