Determining the factors impacting the amount of Work done
The discussion centers on the relationship between the force required to push an oven up a ramp and the work done in both scenarios. It is established that pushing the oven up a 4m ramp requires more force due to the ramp's length, yet both scenarios theoretically require the same amount of work if friction is ignored. Participants debate the impact of friction, noting that it complicates the situation by affecting the normal force and the angle of applied force. The cosine aspect of the force equation is also discussed, with some uncertainty about its relevance when friction is considered. Overall, the conversation highlights the complexities of calculating work done in the presence of friction and varying angles.
BiggestAfrica
Suppose you are moving an oven onto the back of a truck which is 1.5m above the ground.
1. Would pushing the oven up a ramp 4m long require more force than pushing the oven up a ramp 10m long?
2. Would pushing the oven up a ramp 4m long require more work than pushing the oven up a ramp 10m long?
W = FdcosѲ
Apologies for my fairly undescriptive title, I'm having trouble coming up with a better one.
I'm simply trying to verify whether my understanding of this problem is correct.
1. Pushing the oven up a ramp 4m long would require more force (my reasoning here is based on the results of a lab which I'm confident about, which suggested that there is an inverse relationship between length of ramp and applied force)
2. Both scenarios would require the same amount of work to be done, as both the distance and angle are changing
Yes.
Yes, the same if no friction. (Any thoughts on how friction might change that?)
But the reason you give only says they could be the same. Can you offer an argument that says (friction aside) they would be the same?
haruspex said:
Yes.
I'm completely unsure about friction... I initially thought that they would be the same due to the distance increasing while the angle decreased, until I recalled that Ѳ is the angle between force applied and displacement vector. Now I think it's possibly due to the cosine aspect of the equation being negligible (cos0 = 1), but I'm not entirely confident in that reasoning.
Since your original question did not mention friction, I would guess you are supposed to assume there is none. I only asked to see if you had any thoughts on that.
You would need to think about the magnitude of the normal force. It is complicated by the issue of the angle at which the force is applied. When there is friction, you can do better than applying the force parallel to the ramp. So you would first have to decide which case you wanted to consider, parallel to the ramp or optimal angle.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
