Determining the interval between two F1 cars
In summary, the interval time between machines A and B is equal to the time it takes for the second machine (the machine with the smaller speed) to cover their difference in distance.
ilasus
49
Thread moved from the technical forums to the schoolwork forums
Two cars A, B move in the same direction with the constant speeds v, u (v < u) on a rectilinear OM circuit, specially built for Formula 1 cars. Assuming that at the initial moment (t = 0), the two cars are on the starting line O (x = 0) of the OM circuit and that, during t, the cars A, B travel the distances
x1 = v t, x = u t
in relation to O, the question is what is the interval time tAB between machines A and B.
My solution. In the case of Formula 1 cars, the time between them is measured using transponders that transmit radio waves to timing loops placed on the circuit: when a car passes over a timing loop, a system will begin to time how long until it takes as the next car to arrive exact the same spot, when the time between the two cars is established - which can be constant or variable over a certain distance. In the case of machines A, B, the time tAB between them is uniformly increasing and is measured from the moment t1 when machine B is at a distance x1 from the starting line O, until moment t when machine A is at the same distance x1 from O, so the time tAB is given by the relation
tAB = t – t1
where
t1 = x1/u = (vt)/u = (v/u2) x
What do you think?
Likes Delta2
In my opinion the time interval ##t_{AB}## is equal to the time it takes for the second machine (the machine with the smaller speed) to cover their difference in distance, that is $$t_{AB}=\frac{x-x_1}{v}=\frac{x}{v}-\frac{x_1}{v}=\frac{u}{v}t-t=t(\frac{u}{v}-1)$$
ilasus said:
x1 = v t, x = u t
First you have to define what is the meaning of the "interval time between machines A and B". Without this, anything goes. It is your personal definition.
The ”time interval tAB” simply means the time gap btween machines A and B – it is noted on the side of the live leaderboard on TV during a race F1. But how is it correct calculated, like me, or like Delta2? Thank you.
Likes Delta2
You will have to ask the people who use this "quantity". There is no meaningful discussion about a quantity whose definition is unknown.
Likes Orodruin
It isn't unknown definition, he gave his definition , I gave mine, maybe we can prove that the two are equivalent.
Now that I read post#1 more carefully, the definition there is exactly what they do in F1, so I think it is correct.
Don't know how i came up with my own definition lol.
Likes berkeman
Then what is the point to ask how is it calculated, if the definition is really given?
I think they are equivalent. The lap times (and finishing positions) are determined by when the front of the vehicle or person crosses the finish line (since the front of the vehicles or persons are staged right at the start line to begin the race). That is true in pretty much all kinds of racing that I'm familar with.
https://www.westend61.de/en/imageView/CAIF18490/runners-crossing-finish-line-on-track
I see no definition of ##x_1##. I am guessing it is the length of the circuit.
Whatever, we want the time difference in covering distance ##x_1##, but in terms of what?
Seems to me "x" and "t" are not 'given' values, they are just variables used to describe general relationships. So the form of the answer cannot include either of those. This leaves only u, v and ##x_1##.
For example, suppoze that u = 5 m/s, v = 4 m/s, t = 10 s, x1 = 40 m and x = 50 m (x = 50 m is length of the circuit). In this case, I consider that tAB = (x - x1)/u = 2 s, and Delta2 says that tAB = (x - x1)/v = 2.5 s. So our views are not compatible. How is it correct?
Likes Delta2
As I wrote in post #9, "x" cannot feature in the answer. It has no specific value. It is only used as the generic position of the faster car at an arbitrary time t.
As implied in the problem statement, the apparatus detects the time at which the faster car reaches a particular distance ##x_1##, then measures how long it takes the slower car to reach the same point. Express that time in terms of ##x_1, u, v##.
Likes Delta2
haruspex said:
the apparatus detects the time at which the faster car reaches a particular distance x1, then measures how long it takes the slower car to reach the same point
Yes I think that's exactly what they do in F1 and other racing championships.
And how is it correct: tAB = (x-x1)/v or tAB = (x-x1)/u ?
if I follow @haruspex advice at post #11, I think the correct answer is ##\frac{x_1}{v}-\frac{x_1}{u}##. x should not feature in the answer
As I explained in post #9 and in post #11, neither of those is a correct answer.
I wanted to give the OP a bit more opportunity get there.
Likes Delta2
Haruspex:
- I don't understand your answer # 9 and # 11
- What does "OP" mean?
- "get there" - where there?
- Can you give a simple and clear example to understand what you mean?
ilasus said:
Haruspex:
"OP", on these forums, means either Original Post (post #1 in the thread) or Original Poster, the person who created the thread: you in this case.
Getting there means arriving at the answer.
The way the problem is stated in post #1 is rather confusing. I'll attempt to rewrite it to make it clearer:
"Two cars A, B move in the same direction with the constant speeds v, u (v < u) on a rectilinear OM circuit, specially built for Formula 1 cars. Assume that at t = 0 the two cars are on the starting line, O.
So at any given later time
t, car A has gone distance vt and car B has gone distance ut.
... the time
tAB between them ... is measured from the moment ... when machine B is at a distance x1 from the starting line O, until moment ... when machine A is at the same distance x1 from O"
Note that "x" no longer appears and that "t" is not a specific time. The only data you have to work with are u, v and x1. You need to find an expression for tAB which only uses those three variables.
Likes Delta2
haruspex said:
So at any given later time t, car A has gone distance vt and car B has gone distance ut.
So at any given later time t, car A has gone distance x1=vt and car B has gone distance x=ut. Therefore, if v=au, (0<a<1), then x1=ax. Specifically, if u=5m/s, v=4m/s, then a=4/5 and x1=(4/5)x. So:
- if t = 1s, then x1 = 4m, x = 5m, t1 = (x-x1) / u = 1/5 seconds
- if t = 2s, then x1 = 8m, x = 10m, t1 = (x-x1) / u = 2/5 seconds
- if t = 10s, then x1 = 40m, x = 50m, t1 = (x-x1) / u = 10/5 seconds. Understand?
What you think about this video ?
Is it relevant to the question in post #1? If so, what is it about the video that you seek my opinion on?
If you are still interested in the answer to post #1, please post your attempt using my hints in posts #11 and #18.
Yes.
Car A in post #1 is O' in the video
Car B in post #1 is M in the video
And the time tAB from post #1 is t2 in the video.
In the video I also answer the question from post #1.
But you can only refer to the video.
So what do you think about the content of the video?
ilasus said:
Yes.
I don’t see the relevance. F1 cars do not move at relativistic speeds.
Thanks for the reply, but the video doesn't talk about relativistic velocities or TR. In order to see the relevance you are referring to and to present your own opinion, you should watch the video first. If you don't like videos, then read the attached PDF article.
  • MotionE.pdf
The art of solving physics homework problems is the art of slicing away the irrelevant and concentrating on the relevant details. Reducing the problem to one (or a few) simple equations which can be solved for the desired answer.
A video expounding on the Galilean (Newtonian mechanics) and Lorentz (special relativity) transforms just adds unnecessary complexity. One uses those transforms when shifting from one frame of reference to another. This problem can be solved from a single frame of reference: the track frame.
What is needed is simplicity. Which @haruspex is laboring to provide by concentrating on a clear formulation of the problem. "A question well asked is half solved."
Likes SammyS
The reality is not quite as simple as we would like.
But the reality of physics homework questions is.
I will not watch a video just to find your answer to the question in post #1. That answer is a few lines of algebra.
OK
In the video I refer to a mobile M moving with speed u on a road R and I state that the movement with speed u of mobile M on the platform R' is virtual. Hence the formulas (4), (4') which, for u=c, are identified with the Lorentz transformations. So in my video it is a deduction by methods of classical physics, of Lorentz transformations.
  • #31
It's not a valid reference for PF discussion.
Neither is this article.
FAQ: Determining the interval between two F1 cars
How is the interval between two F1 cars measured?
The interval between two F1 cars is typically measured using a stopwatch or timing system. This can be done manually by starting the timer when the first car passes a specific point and stopping it when the second car passes the same point. Alternatively, some tracks have electronic timing systems that can accurately measure the interval between cars.
What factors can affect the interval between two F1 cars?
The interval between two F1 cars can be affected by a variety of factors, including the speed and performance of each car, the track conditions, and any changes in weather or visibility. Additionally, driver skill and strategy can also play a role in determining the interval between cars.
How do F1 teams use the interval between cars to their advantage?
F1 teams can use the interval between cars to their advantage by strategically timing pit stops or overtaking maneuvers. By closely monitoring the interval between their own car and competitors, teams can make decisions on when to make a pit stop or when to attempt to overtake another car on the track.
Can the interval between two F1 cars change during a race?
Yes, the interval between two F1 cars can change during a race. As cars make pit stops, encounter traffic, or experience changes in performance, the interval between them can increase or decrease. Additionally, changes in track conditions or weather can also impact the interval between cars.
How is the interval between two F1 cars used to determine the winner of a race?
The interval between two F1 cars is not used to determine the winner of a race. In F1, the winner is determined by the first car to cross the finish line after completing the designated number of laps. However, the interval between cars can be used to determine the podium finishers and final standings of the race.
