MHB Determining the sin theta, tan theta and cos theta at P (x,y)
To determine sin, cos, and tan values at point P(x, y) on the terminal arm of angle v, the correct formulas are sin(v) = y/√(x²+y²), cos(v) = x/√(x²+y²), and tan(v) = y/x. For point (3, 4), tan(v) is correctly calculated as 4/3, leading to an angle θ of approximately 53.13 degrees. The confusion arises from the distinction between finding the angle θ and calculating the trigonometric functions at that angle. The textbook's instructions were unclear, causing frustration with the online course. Accurate calculations of sin and cos at the specified points are essential for completing the task.
Tazook
Determine the values of sin v, cos v, and tan v at each point P(x, y) on the terminal arm of an angle v in standard position.
(b) (3, 4) ( (d) (12, 5)
(f) (7, 24)
for b I was able to do
tan \theta= y/x
tan \theta= 4/3
\theta = 53.13
My textbook says I am wrong... doing an online course... teacher is so lazy that she never posted how to do it but rather read txtbook pg... Did not help...
Mathematics news on Phys.org
(f) (7, 24)
tan \theta= y/x
tan \theta= 4/3
\theta = 53.13
$$\sin{\theta} = \frac{y}{\sqrt{x^2+y^2}}$$
$$\tan{\theta} = \frac{y}{x}$$
$$\cos{\theta} = \frac{x}{\sqrt{x^2+y^2}}$$
(f) (7, 24)
tan \theta= y/x
tan \theta= 4/3
\theta = 53.13
Ah -- I see your trouble here. What you have should be almost correct.
What skeeter recommended is what you (sort of) did.
You are right that $\theta = 53.13$ degrees.
But the question is not asking you to find $\theta$ but the values of $\sin \tan \cos$ at the value of $v = \theta$
In my point of view,
$\tan(\theta) = \frac{4}{3}$ is indeed correct because you correctly did
$\tan(\theta) = y/x$ but instead you took $\arctan(y/x)$ instead of giving $\tan(\theta)$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
