Determining the transfer function of a humidity chamber
The discussion centers on developing a humidity chamber integrated with a temperature chamber for an undergraduate project. The user is attempting to control the humidity using a humidifier with a relay activated by a PWM signal, alongside a fan and an analog humidity sensor for feedback. They are struggling to model the system and determine the transfer function, particularly how to relate the PWM duty cycle to the sensor's voltage output. Recommendations include ensuring proper diffusion of moisture to prevent condensation and conducting experiments to gradually increase humidity levels. The user aims to design a PID controller to manage humidity effectively while considering the interaction between the humidity and temperature systems.
Ben Jamin
I have created a mock up of a humidity chamber which i will soon be integrating into a temperature chamber for undergraduate project. I am confused on how i can control the system. I have currently a humidifier with a relay built in, this relay is going to switch on and off from a PWM signal generated in a controller. Also within the chamber i have a mini fan to mix the steam and a analogue voltage output humidity sensor which i can use to get feedback from the system. At the moment all of these are linked up to a computer but i need to design the controller. I was thinking PID.
Im having trouble modelling the system to work everything out. The plan was to introduce a step response in terms of duty cycle so say 20% and then check the corresponding voltage output obtained from the sensor.
Im having trouble working out how i can find the transfer function of the system and generally modelling the system for control analysis. How can a step response in terms of % create a transfer function with an output in volts.
The humidifier runs at 6 volts so its either switched on (6 volts) or off (0 Volts)
Once iv done this i need to design the controller
Any advice would be great thanks.
Welcome to the PF.
The humidity chambers that we use at work typically are pretty closed systems, so you don't lose much humidity from just air circulation. So you need to add humidity very slowly, or you will cause condensation, which is a bad thing generally in humidity testing.
So I would focus on how you can diffuse the moisture well in the air stream before it gets into the main chamber, to be sure you don't get condensation. Then you can do some experiments to see what it takes from the humidifier to slowly ramp up the humidity in the chamber. In most chambers that I've worked with, it takes hours to ramp the humidity up and down.
Thanks for your reply, my lecture recommended that i simply insert a generic household or office humidifier into a cardboard box and introduce a step response in the duty cycle (It runs off a PWM signal). Then he recombined i develop a controller with the ability to alter the humidity given a set point.
From your response it seems my main concern is mixing the steam into the airstream, the problem is the humidifier runs off a system where its switched on, or off. Theres no control of how much steam it produces. How would you recommend me ramping up the humidity just for the purpose of developing the controller. In the main chamber it will be introduced through a piping system which circulates the air using a fan and will be coupled with a temperature system. Hopefully the controller can be developed to decouple the two by introducing a step response to each system and finding the inverse of these to alter the transfer function.
Thanks for your help!
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
