Diameter of the football players' piston?
  • Thread starter Thread starter benedict9999
    Diameter Piston
The discussion centers on calculating the diameter of a piston used to lift four football players with a hydraulic lift. The initial calculation attempted to relate the weight of the cheerleader and the players through their respective piston diameters. Participants noted potential calculation errors and discussed the importance of cross-multiplication and significant figures. After reevaluation, the correct diameter for the football players' piston was confirmed to be approximately 55.86 cm. The thread highlights the importance of careful calculations in physics problems.
benedict9999
A 54.0 kg cheerleader uses an oil-filled hydraulic lift to hold four 130 kg football players at a height of 1.40 m. If her piston is 18.0 cm in diameter, what is the diameter of the football players' piston?
54 /18^2 = 520/x^2
x= 55.85696 cm
What am i doing wrong?
Run that through your calculator again; looks like a calculation error.
Might be worth writing out the cross multiplication step.
it's not... I still get the same answer running it through my calculator
Why do you think it is wrong?
Sig figs perhaps?
Edit: I must admit thread subject made me wonder if it is not XXX site link spam...
Sorry, I made the mistake! Checked it again and got your answer.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
