Diamond oxidation -- covalent bonds
  • Thread starter Thread starter PatrickP2
    Bonds Oxidation
To oxidize a diamond, the covalent bonds must be broken, which occurs when diamond is heated in the presence of air. At 150 degrees Celsius, diamond can oxidize to carbon dioxide (CO2), but the activation energy required for this reaction is 220 kJ/mol. Calculations using the Arrhenius equation indicate that at 140 degrees Celsius, the reaction would take an impractically long time—approximately 480 million years—before any noticeable effects occur. Therefore, heating a diamond at this temperature is insufficient for oxidation to take place within a reasonable timeframe. The discussion highlights the significant energy barrier for diamond oxidation and the long duration required for any observable reaction at lower temperatures.
PatrickP2
In order for a diamond to oxidize, do the covalent bonds have to be broken? What would happen if I put the diamond in an oven heated to 150 degrees Celcius? Would the reaction start and after some time the stone would disappear?
Chemistry news on Phys.org
No idea if 150°C will be enough, but yes, diamond heated in the air oxidizes to CO2.
I did a little research and found a study on the oxidation of diamond. It shows that the activation energy is 220 kJ/mol, while the pre-exponential factor is 4.3×10^11 per second. I used the Arrhenius equation and calculated that at 140 C the reaction would take place after 480 million years. I don't know if my reasoning is right, because I have little to do with chemistry and physics, but it seems that 140 C in the oven is not enough after all. :D
Here's the equation I used:
https://www.wolframalpha.com/input?...iusEquation",+"A1"}+->"4.3×10^11++per+second"
No idea how they define the characteristic time, typically it would be something like half life, so it is not like "reaction takes place after", more like "after comparable time effects of the reaction are obvious".
Obviously depends on how long you can wait :wink:
  • Haha
Likes Vanadium 50 and PatrickP2
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
