PatrickP2
- 15
- 2
Can someone explain to me why at room temperature acids cannot dissolve diamond? Is it related to its hardness?
What do you mean?Vanadium 50 said:To help focus the answer, why do you think they should?
PatrickP2 said:What do you mean?
The reason I mention this is that the acid is capable of dissolving glass.Vanadium 50 said:Hydrofluoric is a weak acid. It's about as strong as vinegar.
Why bring it up?
In fairness to the OP, I'm the one who brought up glass.symbolipoint said:Diamond is a very different chemical than most "glass".
It seems that the surface of carbons are reactive (not surprising), so perhaps strong reagents could eat away at the outer layer, and slowly compromise the structructure, but at room temperature? Unlikely.DrJohn said:I suspect that by dissolve the OP actually means react.
For example a metal dissolving in acid is reacting, but I'll bet someone will come up with an exception to this. Also when stating hydrofluoric acid dissolves, glass, it is reacting with it. But mainly ignore HF when thinking about acids in general.
If so, the OP should consider what diamonds are composed of, and then ask does that element react with acids. And then ask is there something special about the structure of diamond.
Who could forget Plenty O'Toole. (Named after her father)symbolipoint said:Diamonds Are Forever!
