Did i do this question completely wrong? (Statics-moment)
  • Thread starter Thread starter lc99
The discussion revolves around a student's concerns about converting units incorrectly on a statics exam question. The student converted lengths from millimeters to meters but did not adjust the torque value from 450 N-m to 0.450 kN-m, leading to discrepancies in their final answers. Other participants confirm that while converting mm to m is acceptable, failing to convert the torque value affects the results significantly. The student realizes that this oversight caused their calculated support forces to be incorrect. Overall, the conversation emphasizes the importance of consistent unit conversion in statics problems.
lc99
I had this question on my final exam and i think i got the wrong numbers because i converted the mm into meters for all of them. So i kept F=3kN , 450N*m , and 3kN as is and used meters instead of mm for the lengths. Would this affect my final answer?
What was your final answer?
If that was your only mistake, you should get some worthwhile credit.
Changing mm to m is fine but if you use force in kN, then your 450 N-m couple should be converted to 0.450 kN-m. Did you do that?
For normal force A , i got like -474 kN . So basically i got the wrong support forces and so i used the wrong numbers.
Ahh man. I did not do that. Uhgh. No wonder nothing matched up.
I did all the steps that needed to be done like finding the equations for shear and bending moments. But it just did not match up with the actual problem. UGH
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
