Did Tsar bomba explosion seen in Finland ?
  • Thread starter eldorado
  • Tags
    Explosion
In summary: If that's the case then the explosion must have been pretty high up. Once again, thanks for your help!
eldorado
Hello :)
When I read about Tsar Bomba, I find that all sites say "The fireball touched the ground, reached nearly as high as the altitude of the release plane and was seen and felt almost 1,000 kilometres (620 mi) from ground zero."
Diameter of the fireball is 8 km.
Now , there are some premises :
1 Distance between the explosion & point that fireball seen is 1,000 km.
2 Circumference of the Earth is about 40000 km.
3 Angle between the two lines which passes through center of the Earth & ( ground zero & 1000 km point ) = (1000/40000)*360 = 9 degrees.
4 Sight line of 1000 km point is the tangent of the earth.
5 To see the explosion from 1000 km point , fire must be at least 79.5 km high.
this conclusion came from:
hight of the fire to be seen 1000 km far = ( Radius of the Earth / Cos (9 degrees ) ) - Radius of the earth.so , how could the explosion seen from this distance when the hight of the fire is only 8 km ?
thanks for help :)
The question is essentialy a distance-to-horizon problem - but the other way around
Imagine an observer at the top of cloud looking to a point on the ground in finland
Distance to the horizon is roughly sqrt( 13*h ), with h in metres
So if h is 8km, 8000m, the horizon is = 320 km, so no you can't see the cloud directly.
You might have seen a flash due to the explosion illuminating high level clouds and reflecting the light, or some atmopsheric effect of exciting ions in some upper level.
Tsar Bomba was a 57 megaton hydrogen-bomb (which was decimated from its originally intended size of 100 megaton by removing material) and it is the largest device ever detonated on this Earth (at least in atmosphere). In 1961. Everybody got the message. Yes, it was reported as seen in Finland. And the blast wave was recorded three times (it circulated the earth). OK, so we know that you can blow it all up. So what? What now? Let's talk.
Thanks a lot for help :)
could you guide me to articles about this effect of illumination & the atmospheric ions ?
Thanks a lot :)
The diameter of the fireball might have been only 8 km, but I'm sure it didn't just chill there until it disappeared. I wouldn't be surprised if it rose to pretty close to the height that you calculated, where it could have been seen from Finland...
Related to Did Tsar bomba explosion seen in Finland ?
1. Is it true that the Tsar bomba explosion was seen in Finland?
Yes, it is true. The explosion was so massive that it could be seen from Finland, which is approximately 600 miles away from the test site in Novaya Zemlya.
2. How far away was Finland from the Tsar bomba explosion?
Finland is approximately 600 miles away from the test site in Novaya Zemlya, where the Tsar bomba explosion took place.
3. Did the Tsar bomba explosion have any effects on Finland?
While the explosion could be seen from Finland, there were no significant effects on the country. The blast wave did not reach Finland, and the radiation levels were not high enough to cause any harm.
4. How powerful was the Tsar bomba explosion?
The Tsar bomba explosion was the most powerful nuclear weapon ever detonated, with an estimated yield of 50 megatons of TNT. This is equivalent to 3,800 times the power of the bomb dropped on Hiroshima in 1945.
5. Was Finland informed about the Tsar bomba test beforehand?
No, Finland was not informed about the Tsar bomba test beforehand. The Soviet Union kept the test a secret, and Finland only learned about it after the explosion was seen and reported by Finnish pilots flying over the Arctic Ocean.
  • Astronomy and Astrophysics
  • Math Proof Training and Practice
9K
  • Aerospace Engineering
