- #36
- 19,370
- 25,183
O.k. but we don't have to fall back on rationals here. Epsilontic and continuity will do.Periwinkle said:The question described above is written on pages 74-77 of this book. The reverse is questionable.
fresh_42 said:O.k. but we don't have to fall back on rationals here. Epsilontic and continuity will do.
I can't see why this avoids AC. Formally we did this:Periwinkle said:##\xi(x) = (\min\{x,x_0\}+\max\{x,x_0\})/2##
fresh_42 said:I can't see why this avoids AC. Formally we did this:
\Lambda(x):=\left\{ \xi \in (\min\{x,x_0\},\max\{x,x_0\}) \, : \, \dfrac{f(x)-f(x_0)}{x-x_0}=f\,'(\xi)\right\}
The mean value theorem guarantees us that all ##\Lambda(x)\neq \emptyset##, but we need more: namely a function $$\xi \, : \, [a,b]-\{x_0\}\longrightarrow \bigcup_{x\in [a,b]-\{x_0\}} \Lambda(x)$$
Narrowing the interval doesn't change the argument.
What you wrote is correct so far. But the question was to determine the spectrum, i.e. the complement of the resolvent set, not the point spectrum of eigenvalues.SpinFlop said:Attempt at Problem 4
Part a) follows directly from the fundamental property of self adjoint operators.
$$ (\hat T{\mathbf a})\cdot{\mathbf b} = {\mathbf a}\cdot(\hat T{\mathbf b})$$
where ##\hat T## is a self-adjoint linear operator and ##{\mathbf a},{\mathbf b}## are two vectors in a given vector space.
In the following proof ##{\mathbf a},{\mathbf b}## will be taken as eigenvectors of ##\hat T## with eigenvalues:
$$\hat T {\mathbf a} = \alpha{\mathbf a}\\
\hat T {\mathbf b} = \beta{\mathbf b}$$
First show that eigenvalues of a self-adjoint operator are real:
(\hat T{\mathbf a})\cdot{\mathbf a} = {\mathbf a}\cdot(\hat T{\mathbf a})\\
(\alpha{\mathbf a})\cdot{\mathbf a} = {\mathbf a}\cdot(\alpha{\mathbf a})\\
\alpha^{*}({\mathbf a}\cdot{\mathbf a}) = \alpha({\mathbf a}\cdot{\mathbf a})\\
\alpha^{*} = \alpha
Thus ##\alpha## is real.
Now show that eigenvectors of ##\hat T## with distinct eigenvalues are orthogonal
(\hat T{\mathbf a})\cdot{\mathbf b} = {\mathbf a}\cdot(\hat T{\mathbf b})\\
(\alpha{\mathbf a})\cdot{\mathbf b} = {\mathbf a}\cdot(\beta{\mathbf b})\\
\alpha^{*}({\mathbf a}\cdot{\mathbf b}) = \beta({\mathbf a}\cdot{\mathbf b})\\
\alpha({\mathbf a}\cdot{\mathbf b}) = \beta({\mathbf a}\cdot{\mathbf b})
where the last line follows from the fact that the eigenvalues must be real.
Since the eigenvectors ##{\mathbf a},{\mathbf b}## have distinct eigenvalues this means ##\alpha\neq\beta## and so necessarily ##{\mathbf a}\cdot{\mathbf b} = 0##.
Thus, by definition ##{\mathbf a},{\mathbf b}## are orthogonal.
Part b)
If I understand correctly, for a given function ##f(t)## in the Hilbert space ##\mathcal {H} =L_{2}([0,1])## the linear operator ##T_g## simply multiplies ##f(t)## by the function ##g(t)##:
$$T_{g}(f)(t):=g(t)f(t)$$
If so, then the eigenvalue problem requires
$$g(t)f(t) = \lambda_{g}f(t)$$
The trivial possibility is that the function ##g(t)## is a constant and so we get ##\lambda_{g} = m = M##
If ##g(t)## is not a constant, then I am not so sure I know how to proceed, the only path forward that I see is to define our eigenfunctions as delta functions, in which case our eigenvalue spectrum is continuous over the interval ##[M,m]##.
That will take me awhile, since one of us has made a mistake and I have to figure out who and where.Periwinkle said:$$ (a(x),(b(x)) =\int_{-\pi /2}^{\pi/2} (11\sin(x) + 8\cos(x))\cdot (4\sin(x) + 13\cos(x)) \, dx =
\\ \int_{-\pi /2}^{\pi/2} (44\sin^2(x) + 175 \cos(x) \sin(x) + 104 \cos^2(x)) \, dx =
44 \pi /2 +104 \pi/2 = 148 \pi /2. $$
$$ \left|a \right| ^2 = (a(x),(a(x)) =
\\ \int_{-\pi /2}^{\pi/2} (121\sin^2(x) + 176 \cos(x) \sin(x) + 64 \cos^2(x)) \, dx = 121 \pi /2 +64 \pi/2 = 185 \pi /2.$$
$$ \left|b \right| ^2 = (b(x),(b(x)) =
\\ \int_{-\pi /2}^{\pi/2} (16\sin^2(x) + 104 \cos(x) \sin(x) + 169 \cos^2(x)) \, dx = 16 \pi /2 + 169 \pi/2 = 185 \pi /2.$$
$$ \cos(\phi) = \frac {(a(x),(b(x))} {\left|a \right| \left|b \right| } = \frac {148 \pi /2} { 185 \pi /2 }= 0.8. $$
$$ \phi = 0.6435. $$
fresh_42 said:That will take me awhile, since one of us has made a mistake and I have to figure out who and where.
Correction: We were both right. I forgot a square root in the denominator.
How do you find my solution:
We define ##f(x)=\sin(x)-6\cos(x)\; , \;g(x)=6\sin(x)+\cos(x)## and observe, that ##\{\,f,g\,\}## is a orthogonal basis for a two dimensional subspace of ##L^2\left( \left[ -\frac{\pi}{2},+\frac{\pi}{2} \right] \right)## with ##\gamma :=|f|=|g|=\sqrt{\dfrac{37 \pi}{2}}##. As we are interested in an angle, we won't have to bother the length of our coordinate vectors, i.e. we do not need to normalize them. Now we have ##a=-f+2g\, , \,b=-2f+g## and
\begin{align*}
\cos \varphi &= \cos (\sphericalangle (a,b))\\
&= \cos(\sphericalangle (-f+2g,-2f+g))\\
&= \dfrac{\langle -f+2g,-2f+g \rangle}{|-f+2g|\cdot |-2f+g|}\\
&= 2 \; \dfrac{\langle f,f\rangle + \langle g,g \rangle}{\sqrt{\left( |f|^2+4|g|^2\right)} \cdot \sqrt{\left( 4|f|^2+|g|^2 \right)}}\\
&= 2\; \dfrac{\gamma^2+\gamma^2}{\sqrt{5\gamma^2 \cdot 5\gamma^2}}\\
&= \dfrac{4}{5}
\end{align*}
and ##\varphi \approx 36.87° \approx 0.2 \pi##
Correct. It could be said a bit shorter if we don't specify a potential inverse:Periwinkle said:Question 4
Self-adjoint linear operator's eigenvalues are real $$ \lambda (x,x) = (\lambda x, x) = (Ax,x) = (x, Ax) = (x,\lambda x,) = \bar \lambda (x,x) $$ However, in the Euclidean space ## (x,x) =0 ## follows ##x = 0##, so ## \lambda = \bar \lambda##.
The eigenvectors belonging to different eigenvalues are orthogonal $$ (Ax, Ay) = (AAx, y) = (\lambda _1 Ax, y) = \lambda_1^2(x,y) $$ $$ (Ax, Ay) = (x, AAy) = (x, \lambda _2 Ay) = \lambda_2^2(x,y) $$ Because ##\lambda_1## and ## \lambda_2## is different, so ## (x,y)## is equal to ##0##.
The spectrum of the ##T_g## operator is the interval ##[m,M]##...
