Dielectric constant depression of water?
The discussion centers on the challenges of calculating the dielectric constant for a project involving quantum dots and wires in water, specifically the cytoplasm of a cell. The dielectric constant of water is significantly higher than desired, impacting coupling efficiency. Participants suggest methods to lower the dielectric constant, including adding salt and considering supercritical water, but caution against freezing due to potential cellular immobility. Additionally, it is noted that the dielectric constant varies with the frequency of electromagnetic radiation, decreasing at higher frequencies. Overall, the conversation highlights the complexities of manipulating dielectric properties in biological environments.
excalibur313
Hey Everyone. I am doing a project proposal where I am calculating the coupling efficiency between a quantum dot and a wire and I need to enter in values for the dielectric constant of the wire and the surrounding medium. I am working off a paper (doi:10.1103/PhysRevB.76.035420) where he uses the dielectric constant for the surrounding medium to be 2. I would like to do this in water (well actually the cytoplasm of a cell which I think is ~50) which has a much higher dielectric constant and unfortunately it seems to kill off the really efficient coupling that I was getting. Does anyone know of a way to suppress the dielectric constant and to somehow quantify how low I can get it? I know salt will depress it, but how much would I expect? I read that if I get water at a supercritical phase I can get it pretty low, but does anyone know of any other way? Thanks a lot for your help!
Freezing will help, if you also drop the temperature below 0. Maybe that is what you mean by supercritical phase. Also, the dielectric constant is a function of the frequency of the EM radiation in question, and drops with increasing frequency.
Here is a quote off of the web: "The dielectric constant of ice at 0°C is virtually the same as that of water (88.0), but decreases rapidly with decreasing temperatures below 0°C, and with increasing frequency; by 0.1 MHz, kice ~ 2-4 with little influence of temperature." Source - http://www.nanomedicine.com/NMI/10.5.5.htm
I don;t think freezing is a good idea. It would solidify the medium and render the cells immobile
10K
