Dielectrical constant / relative permittivity
The discussion focuses on the relationship between relative permittivity and charge levels in capacitors. It is noted that while the charge affects the electric field through the dielectric, in an ideal capacitor, permittivity remains constant regardless of the field. However, real capacitors exhibit some nonlinearity, particularly at high voltages, which can lead to breakdown. The conversation confirms the initial understanding that relative permittivity is generally independent of charge in ideal conditions. Overall, the nuances of dielectric behavior in practical applications are acknowledged.
nikkebargell
Hi!
Im woundering if the relative permittivity in a capacitor is dependent on
the level of charge in the capacitor?
/Nikke.
The charge on the capacitor affects the E field through the dielectric. In an ideal capacitor the permittivity is independent of field. Real devices have some degree on nonlinearity (eg at high voltages they will simply break down).
ok cool, that's what i thought.
cheers
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
