Difference between centrifugal force vs reactive centrifugal force?
In summary: In this case, the term "reactive centrifugal force" would be more accurate, as the force is reactive to the motion of the body.In summary, the difference between centrifugal force vs reactive centrifugal force is that centrifugal force is the force exerted by an object in a rotating reference frame while reactive centrifugal force is the force exerted by an object in a co-rotating frame. The interaction forces (also called “real forces”, but I prefer the term “interaction” as it is less philosophical and more descriptive) arise from interactions between objects. Importantly these interactions follow Newton’s
  • #36
jbriggs444 said:
I think that you mis-spoke here, @Dale.
Oops, quite right. I have edited it to fix it
  • #37
Aeronautic Freek said:
I still don't understand why Ficf and Frcf are not same in magnitude...
can you make simple example with numbers..
##F_{rcf}=m_{man}r_{station}\omega_{station}^2##. Note that ##\omega_{station}## is the angular velocity of the station as measured in an inertial frame, so this quantity is frame independent.
##F_{icf}=m_{man}r_{station}\omega_{frame}^2##. The angular velocity of the frame can be anything. If you imagine the diagrams A. T. drew to be photos taken with a camera, ##\omega_{frame}## is the angular velocity of the camera. This has no effect on the situation being filmed. It could be zero, in which case ##F_{icf}=0## and you have an inertial frame. You could set the camera spinning at half the rate the station spins, in which case ##F_{icf}=F_{rcf}/4##. In the case that the camera spins at the same rate as the station, ##F_{icf}=F_{rcf}##.
The point is that ##F_{icf}## is a force you have to introduce if you want to use Newton's laws in their simple form to describe motions as recorded by a spinning camera. ##F_{rcf}## is a real force the man exerts on the station floor.
Likes Aeronautic Freek
  • #38
Take the example of a rock attached to a string being spun in a circle in space (no air and no gravity). Let the mass be 1 kg, the radius be 2 m, and the tangential velocity be a constant 10 m/s. (all numbers in SI units)
In an inertial frame (##\omega=0##):
##F_{icf}=m\omega^2 r=0## acting on the rock
##F_{rcf}=mv^2/r=50## acting on the string
In a co-rotating frame (##\omega=5##):
##F_{icf}=m\omega^2 r=50## acting on the rock
In a frame rotating at double speed (##\omega=10##):
##F_{icf}=m\omega^2 r=200## acting on the rock
  • #39
Here start all my problems I didnt have solution in my head that you can spin camera at different ang.velocity than station.But why you will do that!
I allways thinking when talking about rotating frame ,that camera is attached on station,so now it is part of station ,so normaly it spins at same ang.velocity as station..So Frcf must be equal to Ficf
  • #40
Thanks ,with your example with numbers and post 37# with camera example, now is clear.
Whish you write this at biginning of topic! :)
(probelm is i didnt know that reference frame can spins with different ang.velocty than station)
I allways have only two rafrerence frame in my mind.
inertial-when I watch merrygoaround from outside
and roating (non-inertial)when I am in merry-go around so I spin with him at same rate...
  • #41
This thread shows again that one shouldn't invent unnecessary vocabulary which isn't used in a wider physics community anyway. I've never heard about "reactive centrifugal forces" before, and I do not see what they are in the here discussed example nor what they are good for.
The usual way the expression "centrifugal force" is used is that of a specific part of the socalled inertial forces in a rotating reference frame in Newtonian mechanics (rotating against inertial reference frames of course). The inertial forces come from bringing parts of the covariant time derivative defining acceleration as the 2nd time derivative of the position vector when expressed in components wrt. the rotating basis of the rotating reference frame to the right-hand side such as to make the equation look like in an inertial frame with additional "inertial forces" on the right-hand side. This is sometimes customary if you want to think about what's going on in a rotating reference frame. We live in one, because the Earth rotates once a day around its axis, and for some physics we cannot ignore this rotation against the inertial frames (e.g., the physics of the Foucault pendulum, which is treated in any introductory physics lecture on classical mechanics, the rotation direction in cylones and anticyclones on both sides of the equator,...).
It is a very good practice, hammered into us by good teachers in high school and professors at universities to talk about the centrifugal force if and ONLY if one refers to a rotating reference frame and the one specific part of the inertial forces in such a rotating frame: ##\vec{F}_{\text{centrifug}}=-m \vec{\omega} \times (\vec{\omega} \times \vec{r})##. Here ##m## is the mass of the particle, ##\vec{\omega}## the momentary angular velocity of the rotating basis against the inertial basis, and ##\vec{r}## the position vector, all given as components with respect to the rotating basis.
Likes JD_PM, etotheipi and Dale
  • #42
It was not invented here, but I also dislike the term. For one thing, the reaction to a centripetal force can be another centripetal force, as in the case of circular orbits in Newtonian gravity.
  • #43
In Newtonian gravity, I guess you refer to the Kepler problem of a planet moving around the Sun, I guess. This problem you treat of course in an inertial frame of reference, and the force you have there is the gravitational force, which of course provides the centripetal force of the planet to keep it on its circular (or elliptic orbit). In this problem there's no other force than the gravitational force and not "another centripetal force", or what should that be?
  • #44
There is the gravitational force of the sun acting on the planet. The third law pair to that force is the gravitational force of the planet acting on the sun. Both forces are centripetal.
  • #45
Only if the orbit is a cricle. In elliptic case force of gravity as a whole is not a centripetal force, only its component perpendicular to ellipse.
  • #46
Well, that depends on what you take as the "center". If one uses the barycenter then gravity is purely centripetal at all times. If one uses the instantaneous center of curvature of the trajectory then gravity is only purely centripetal at two points, as you point out.
  • #47
Yes. Which is why I said:
(emphasis added)
  • #48
[reference frame] spins at same ang.velocity as station..So Frcf must be equal to Ficf
Not in general, only in the most simple scenarios like this one. For example, if the two astronauts in the station were also connected by a rope under tension, then the Frcf would be reduced, and its magnitude no longer equal to Ficf in the co-rotating frame.
Reference frames are just abstract constructions, like coordinate systems. Their movement doesn't have to coincide with the movement of any physical object.
  • #49
But then in that case, can one use the formula for centripetal force ##\frac{mv^2}{r}##? I guess not, since this formula adapts the second convention.
Likes jbriggs444
  • #50
Sorry, I missed that post :oldbiggrin:
  • #51
I was under the impression that it is by definition always the latter, i.e. the normal component in intrinsic coordinates, ##\frac{mv^2}{\rho}##.
The component toward the barycentre would I guess be towards a centre of some sort, but it wouldn't be what we call "centripetal force"?
Likes weirdoguy
  • #52
Yes, ##a=\frac{v^2}{r}## fits the instantaneous center of rotation while ##a=\frac{GM_r}{r^2}## fits the barycenter [here, ##M_r## is the "reduced mass" of the other body].
In my book, "centripetal" and "centrifugal" are directions. Literally toward the center and away from the center. But I am not a definition Nazi. Use words as you wish. Just be aware that others may use them differently.
Likes etotheipi
  • #53
Sure, but nowhere (using the usual terminology) is there any centrifugal force.
  • #54
Indeed. There's at least one seventeen page thread on the topic here. However in the ball on a string example, there is a third law pair to the inward pointing centripetal force on the ball and this force is outward pointing. This would be the "reactive centrifugal force". It isn't present for planets because the third law pairs are both centripetal, since there is no mechanical connection between the planets.
I think the problem is that some sources do use the words "centrifugal force" to mean the thing I've called a "reactive centrifugal force", which is most definitely a proper force in the cases where it's present. This is sloppy terminology - even the Wikipedia article on centrifugal force notes this usage as "deprecated" - and is what's causing all the confusion here.
I also agree that "reactive centrifugal force" is not a term I'd come across before the first time I saw this argument on here. I mostly remember it just to answer people like the OP who've confused it with the inertial force.
Likes etotheipi and Doc Al
  • #55
Yes. This is why I dislike the term “reactive centrifugal force”. Sometimes the reaction force to a centripetal force is centripetal, not centrifugal.
Likes Ibix
  • #56
Meanwhile, I dislike the "reactive" part. It reinforces the incorrect notion that there is some sort of asymmetry in a third law force pair. Cause and effect, action and reaction rather than simply two facets of the same interaction.
Likes Doc Al and Dale
  • #57
Excellent! Yet another reason to not like the term
  • #58
What's the normal terminology what you rename "reactive centrifugal force"? There's a string tension here, and it's as centripetal a force as the gravitational force in the planet-Sun (Kepler) example.
Also third law refers always to interactions, i.e., to the forces acting on two different bodies or, for the most general case of general ##N##-body forces, it boils down to the center-of-mass motion, which for a closed system is always uniform and thus finally to global momentum conservation for closed systems as a consequence of homogeneity of space according to Noether's theorem.
Likes etotheipi
  • #59
action and reaction is not a cause-and-effect relation. It's an artifact of Newtonian physics, where you have action-at-a-distance ineractions, which of course is an approximation to real interactions mediated by fields.
  • #60
The outward force of rock on string is clearly centrifugal.
Of course, strictly speaking, string tension is not a force at all. It is a condition in the string. A component of a stress tensor. It is more akin to a force pair rather than to a single member of a force pair.
Likes etotheipi
  • #61
Which outward force? In the inertial frame there's a centripetal force pointing towards the center caused by the tension of the string. Of course tension is a force binding the atoms/molecules together the string is made of. What else should it be? Maybe you are referring to the rigid-body approximation, where you substitute the (elastic) forces by the rigidity constraint?
  • #62
The outward force of rock on string, as I said. That force exists at the interface between rock and string. It has a direction and a location. The direction is unambiguously away from the center of rotation.
Likes Dale
  • #63
Sure, but it's not a centrifugal force but just a force in an inertial frame. As you say, it's a "contact formce". So don't call something a centrifugal (inertial) force in an inertial frame. By definition there are no inertial forces in inertial frames of reference. The wrong wording leads to utmost confusion of the students, as is demonstrated by this thread which consists of 63 contributions just to eliminate the wrong thinking from this wrong wording again!
Likes etotheipi
  • #64
We do not seem to be communicating well.
You referred to string tension as centripetal. I took issue with this. String tension is neither centrifugal nor centripetal. It is a force pair, not a force.
There is a force pair that exists between rock and string. As you agree, it is a contact force. One member of that force pair is directed toward the center. One member of that force pair is directed away. I do not know of a pithy name other than "reactive centrifugal force" to refer to the outward force of rock on string.
Your words seem to suggest that you want to label the outward force of rock on string as "centripetal". But I am sure that is not what you intend.
  • #65
It's in any case NOT a centrifugal force, because there is no centrifugal force in an inertial frame of reference by definition. In you example the force on the rock is due to the tension in the string. At the end of the string the rock's contact force is opposite and of equal magnitude of course (Newton's 3rd law).
  • #66
It is a force that acts in the centrifugal direction. Taking "centrifugal" here to mean literally "away from the center".
Likes etotheipi
  • #67
I think perhaps the intention was that the terminology "centrifugal force" is so overwhelmingly associated with the ##-m\vec{\omega} \times (\vec{\omega} \times \vec{r})## that arises in a rotating frame of reference, that the term "reactive centrifugal force" (even though it's perhaps correct in the sense "fugal ##\equiv## away") is unhelpful for students. Not least because it presents the risk of conflating two very different ideas, just as these last few threads have demonstrated!
Likes jbriggs444
  • #68
I fight against the use of the word "centrifugal" in the context of forces at all as long as we discuss physics from the point of view of an inertial observer, because it's much more economic to avoid misleading language and stick to clear definitions. A centrifugal force is an inertial force and as such can by definition only present in non-inertial (in this case rotating) frames of reference.
Likes etotheipi
  • #69
I don't think that anyone here disagrees with you. The term "reactive centrifugal force" is rather like "relativistic mass". It has a standard known definition that is not from Physics Forums and is not liked by most participants here, but sometimes you see someone who is confused by it and so we have to explain what it means and also why we dislike it.
Likes jbriggs444
  • #70
vanhees71 said:
I fight against the use of the word "centrifugal" in the context of forces at all as long as we discuss physics from the point of view of an inertial observer, ...
I am even more annoyed by the "reactive" part because I dislike the "action/reaction" terminology with respect to Newtons 3rd Law.
Likes etotheipi, vanhees71 and jbriggs444
