Difference between Maxwell-Boltzmann and Maxwell Distribtion?
The Maxwell-Boltzmann Distribution illustrates the distribution of molecular energies in a gas, highlighting the range of energies among molecules, with some having high energy and others low. It provides a more detailed understanding of molecular behavior compared to the original Maxwell Distribution, which primarily focuses on the speeds of gas molecules. The key difference lies in the Maxwell-Boltzmann Distribution's emphasis on energy distribution rather than just speed. Understanding these distinctions is crucial for analyzing gas behavior in kinetic theory. Clarifying these concepts enhances comprehension of molecular dynamics in gases.
Lavace
What is the difference between Maxwell-Boltzmann and Maxwell distributions
in the kinetic theory of gases?
I know that the Maxwell-Boltzmann Distribution shows the energy of molecules against the number. What this shows is a spread of the energies contained within the sample of molecules, where some molecules have a high energy and others low, we can also see the amount of energy most molecules have etc.
I also know that the Maxwell-Boltzmann Distribution is an improvement in the description of energies within a system over the Maxwell Distribution, but am not too sure what the Maxwell Distribution actually is, or how to describe the differences.
If anyone could push me into the correct direction, I will be greatful.
No joy?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
