Difference between N/m^2 and N/m^-2
  • Thread starter Thread starter elecone
    Difference
N/m^2 and N/m^-2 are equivalent units representing pressure, both defined as "Newtons per square metre." The confusion arises with N/m^-2, which is not correct as it implies a different measurement, specifically Nm^2. The distinction is important for clarity in physics and engineering contexts. Understanding these units ensures accurate communication of pressure measurements. Both N/m^2 and N/m^-2 should be used interchangeably for pressure, while avoiding N/m^-2 to prevent misunderstanding.
elecone
My homework questions all state pressure as N/m^-2. what's the difference between N/m^2 and N/m^-2? Thanks
elecone said:
Homework Statement:: My homework questions all state pressure as N/m^-2. what's the difference between N/m^2 and N/m^-2? Thanks
Pressure could be in units of ##N/m^2## or ##Nm^{-2}##. They're the same thing: "Newtons per square metre".
But not ##N/m^{-2}##, which would be the same as ##Nm^2##.
Likes jim mcnamara
that's perfect, thanks
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
