I Difference between the thermal and mechanical efficiency
The discussion centers on the confusion between thermal and mechanical efficiency in Stirling heat engines. Mechanical efficiency is described as the ratio of work done by the gas to the work output of the engine, while thermal efficiency relates to the thermodynamic performance of the engine. Participants emphasize the importance of clear definitions from sources discussing these terms. There is a consensus that mechanical efficiency should not be used interchangeably with thermal efficiency. Understanding these distinctions is crucial for accurate analysis of heat engine performance.
Poorneshwar 2
Hello, I'm confused between the difference between the thermal and mechanical efficiency of a Sterling heat engines or heat engines in general. I hope you could be able to guide and help me. Thank you
Science news on Phys.org
I don't think there is a difference, but I wouldn't use the term "mechanical efficiency" to refer to a thermodynamic system. Where did you hear it?
[Edit] Google tells me "mechanical efficiency" can be used to describe the mechanical output of a real engine (different from themal/thermo efficiency).
I read about the mechanical efficiency of the heat engine in this article. I think that it is the ratio between Qh(work done by the gas) and Wout(work that the heat engine has done). Am i thinking in the right way?
Also, what does thermal efficiency of a heat engine refer to?
Thank you.
That sounds right, but your source should include the definition if it is introducing the term.
I would think thermal means thermodynamic, but it is possible they are also referring to a real-world, non-ideal process. But again, the text you are reading it from should define it.
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
