MHB Difference Between Two Radicals
  • Thread starter Thread starter bergausstein
    Radical
The discussion clarifies the distinction between the square roots of positive and negative numbers, emphasizing that both (1)^2 and (-1)^2 equal 1. It highlights that while the square root of 1 is defined as the positive value, the expression √((-1)^2) is incorrectly stated as -1. The correct interpretation is that √((-1)^2) equals 1, aligning with the definition of absolute value. Thus, the key takeaway is that the square root function returns the principal (positive) root. Understanding this distinction is essential for accurate mathematical reasoning.
bergausstein
can you tell the difference
$\displaystyle \sqrt{(1)^2}=1$$\displaystyle \sqrt{(-1)^2}=-1$
Mathematics news on Phys.org
Use the definition:
$$|x|\equiv\sqrt{x^2}$$
Hence:
$$\sqrt{(-1)^2}=|-1|=1$$
The major difference is that the first one is right and the second one is wrong! Both (1)^2 and (-1)^2 are equal to 1 so both of those is \sqrt{1}. And \sqrt{a} is defined as the positive number, x, such that x^2= 1.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
