MHB Different Kinds of Quantum Computing Measurement Operators
Ackbach
MHB
So in quantum mechanics, there are at least three different kinds of measurement operators: the General, the Projective, and the Positive Operator-Valued (POVM). They have different properties and relationships. In a typical QM book, these are not delineated, but in Quantum Computing they are, since we want to have much more fine control over measurements. So here is a table comparing the three different kinds of measurement operators.
\begin{array}{|c|c|c|c|}\hline
\textbf{Type} &\text{General} &\text{Projective} &\text{POVM} \\ \hline
\textbf{Basic Symbol} &\text{Measurement Op} \; M_m &\text{Observable} \; M=\sum_m m P_m &\text{Measurement Op} \; M_m \\ \hline
\textbf{Special Property} & &P_m \; \text{a projector:} \; P_m^2=P_m &\text{POVM element} \; E_m:=M_m^{\dagger}M_m \\ \hline
\textbf{Probability} &p(m)=\langle\psi|M_m^{\dagger}M_m|\psi\rangle &p(m)=\langle\psi|P_m|\psi\rangle &p(m)=\langle\psi|E_m|\psi\rangle \\ \hline
\textbf{State After Measurement} &\dfrac{M_m|\psi\rangle}{\sqrt{\langle\psi|M_m^{\dagger}M_m|\psi\rangle}}
&\dfrac{P_m|\psi\rangle}{\sqrt{\langle\psi|P_m|\psi\rangle}} &\text{not of interest} \\ \hline
\textbf{Completeness} &\sum_mM_m^{\dagger}M_m=I &\sum_m P_m=I &\sum_m E_m=I \\ \hline
\textbf{Hermitian} &M_{m}^{\dagger}=M_m &P_{m}^{\dagger}=P_m &E_{m}^{\dagger}=E_m \\ \hline
\textbf{Other Special} & &E(M)=\langle\psi|M|\psi\rangle &\text{If} \; M_m^2=M_m \; \text{then} \; M_m=P_m \\ \hline
& &M_mM_{m'}=\delta_{m,m'}I &\text{Otherwise,} \; M_m=\sqrt{E_m} \\ \hline
\end{array}
Also note that, by definition, in the POVM case, $\{E_m\}$ is the POVM.
Moved.
Thanks
Bill
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
12K
