Different types of exponential growth equations?
The discussion focuses on solving a problem related to bacterial growth modeled by exponential equations. The initial population of 100 cells grows to 420 in one hour, prompting calculations for population over time and growth rates. Two forms of exponential growth equations are highlighted: P(t) = Aexp(kt) and P(t) = Ab^t, which can be shown to be equivalent through logarithmic transformations. Clarifications are made regarding the distinction between population size and growth rate, emphasizing the importance of units in calculations. Understanding these equations allows for accurate modeling of bacterial growth and its rates.
NanaToru
A bacteria culture initially contanis 100 cells and grows at a rate proportional to its size. After an hour the population has increased to 420.
a. Find an expression for the number of bacteria after t hours.
b. find the number of bacteria after 3 hours
c. find the rate of growth after 3 hours.
d. when will population reach 10,000?​
This is done in section of the book of expontial growth and decay, so equations
dP/dt = kP
P(t) = P0 e^kt
I [/B]
I managed to solve it, but I had some questions about the exponentials.
For part a, I got
P'(t) = 100P, and if P'(1) = 420, P = 4.2
However, for c., I had to end up taking the differential of P(t) to get P'(t) = 143.5e^1.435t
Ultimately, at t = 1, these give the same answer. But I don't understand how I'm supposed to know when to get either equation... Would my answer for C have been incorrect for A?
dP/dt = kP
P(t) = P0 e^kt
I [/B]
For part a, I got
The answer for C is not the same as for A.
They can't be, they have different units. Take care with your units in each part. P'(t) = 143.5e^1.435t needs units. What are they?
One is a rate (cells/hour), one is just a population (number of cells). It appears I didn't word my question right,. Thank you for your help so far.
But if A is a population equation, and C is a change in rate of population growth, why wouldn't my answer to A have been P(t) = P0e^(kt) form? My book used 100(4.2)^t for (a) and it didn't make sense to me. Is there a way that population rate of growth could've been found from that? Or were they trying to draw some comparison?
There are two ways of modeling exponential growth: P(t) = Ab^t, where A and b are constants and P(t) = Aexp(kt), where A and k are constants.
The way you did it is more common for bacterial growth and any time one solves the same differential equation you posted. One can use simple rules of logs and exponents to shot that the two models are equivalent and to compute the equivalent model in the other form when given one to start with.
Likes NanaToru
Thank you for your help! I understand now.
You can use both Aexp(kt)= Ae^{kt} and Ab^t for the same thing because e^x and ln(x) are "inverse functions": e^{ln(x)}= x. In particular p^t= e^{ln(p^t)}= e^{t ln(p)}= e^{kt} where k= ln(p).
Likes NanaToru and Dr. Courtney
