Differential change of variables
sjw11
I am working on an exam question, I have the solution but i can't figure out a step in between,
I need to show that ∂P/∂r = (1/r)∂ψ/∂r - ψ/r^2
I am wondering where the - ψ/r^2 comes from. I.e. which rule is this, and sencondly how does this apply to higher order differentials.
Thanks in advance for all your help
Stuart
Stuart
Hello Stuart. Welcome to PF !
Without knowing how P, ψ, and r are related, it will be hard to answer your question.
Is that P supposed to be ρ ?
Sammy,
Apologies I forgot to put that in
ψ=rP
p=P not ρ
cheers
Then P = \frac{ψ}{r}
\frac{∂P}{∂r} = \frac{∂}{∂r}(ψ\cdot\frac{1}{r}) = \frac{1}{r}\cdot\frac{∂ψ}{∂r} + ψ\cdot\frac{∂}{∂r}(\frac{1}{r})
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
